What Force Does the 4 kg Block Exert on the 7 kg Block?
  • Thread starter Thread starter PrideofPhilly
    Accelerating Blocks
The force exerted by the 4 kg block on the 7 kg block is calculated to be 11.67 N. This conclusion is derived from applying Newton's second law (F = ma) to determine the net force acting on the blocks. The total force acting on the system is 26 N, leading to an acceleration of 2.17 m/s². The force exerted by the 4 kg block on the 7 kg block is then determined by considering the net force on the 4 kg block and the frictional force acting on the 7 kg block.
  • Understanding of Newton's laws of motion
  • Familiarity with basic physics equations (F = ma)
  • Knowledge of force and mass interactions in a frictionless environment
  • Ability to perform calculations involving net forces and accelerations
  • Study Newton's third law of motion and its applications in force interactions
  • Learn how to analyze systems of multiple blocks and their interactions
  • Explore problems involving frictionless surfaces and net force calculations
  • Practice solving physics problems using free-body diagrams for clarity
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force interactions in multi-body systems.
PrideofPhilly
The horizontal surface on which the objects slide is frictionless. The acceleration of gravity is 9.8 m/s2. Three blocks are sliding on a frictionless horizontal surface:
Fℓ----->[Block1-1kg][Block2-7kg][Block3-4kg]<--Fr
If Fℓ = 29 N and Fr = 3 N, what is the magnitude of the force exerted on the block with mass 7 kg by the block with mass 4 kg?
F = ma
29 N - 3 N = 26 N (total force) 1kg + 7 kg + 4 kg = 12 kg (total mass)
a= F/m = 26 N/12 kg = 2.166666667 m/s2 (acceleration of all the blocks in the right direction)
masses of Block2 + Block 3 = 11 kg
F = (11 kg)(2.166666667) = 23.83333333 N (THIS IS THE WRONG ANSWER!)
What am I doing wrong?
You found the net force on the "Block2 + Block 3" system. Not sure why.
Hint: What's the net force on Block 3? How can you use that result to answer the question asked in the problem?
Net force on Block 3 = (4 kg)(2.166666667) = 8.666666668 N
So, the force of 8.67 N is being exerted on Block 3 from the left, but if I am trying to find the force being exerted on Block 2 from Block 3 (from the right), then would I have to find the net force being exerted by Block 1 and 2? I'm not quite sure.
OR:
The net force on Block 3 + Fr = 8.67 N + 3 N = 11.67 N (force exerted on block 2 by block 3)
Is that right?
Good.
No, 8.67 N is the net force on block 3.
Don't forget Newton's 3rd law: If you can figure out the force that block 2 exerts on block 3, then you automatically know the force that block 3 exerts on block 2.
PrideofPhilly said:
OR:
Is that right?
Yes. Here's how to think of it:
Net Force on Block 3 = + 8.67 N (Positive, since it points right.)
Force of Block 2 on Block 3 + Fr = + 8.67 N
Force of Block 2 on Block 3 - 3N = + 8.67 N (Note that Fr is negative, since it points left.)
Force of Block 2 on Block 3 = + 8.67 N + 3N = 11.67 N
Thus the force of Block 3 on Block 2 = -11.67 N (from Newton's 3rd law); the magnitude is just 11.67 N.
Thank you!
  • · Replies 17 ·
  • · Replies 23 ·
