Three Blocks Two Pulleys and a Table
The discussion revolves around a physics problem involving a system of blocks and pulleys, where the user seeks validation of their solution for the acceleration of block C and the time it takes to reach the ground. The user calculated the net force on block B and derived an acceleration of -4.34 m/s², leading to a time of 0.695 seconds for block C to fall. However, they questioned whether they should have divided the net force by the total mass of all blocks to find the system's acceleration. Other participants confirmed that the correct approach involves considering the total mass since all blocks are interconnected. The conversation emphasizes the importance of free-body diagrams in solving such problems accurately.
RJVoss
This was a problem on an exam I had the other day and I want to know if my attempt was correct.
Please look at the attached image. You have a system of two ideal pulleys set up on a table. Block A is hanging from a string on the left side of the table which passes by a pulley connecting it to block B. Block B is resting on the table, and the kinetic coefficient of friction between the surface of the table and the block is 0.557. Block C is hanging from a string on the right side of the table which passes by a pulley and is attached to Block B. Block C is four times as massive as block A, and block B is three times as massive as block A. When the system is released from rest, block C accelerates downward until it reaches the floor, a distance of 105cm.
Find: The acceleration of block C and the time it takes to reach the ground.
F=ma
FF=\mukN
y = y0 + v0yt + 1/2 at2
N = mg
I started by trying to find the net force acting on block B in order to find the acceleration of the system. In this case,
Fnet= FC - (FA + FF)
so
Fnet= (4mAg) - 1mAg - (\mu3mAg)
simplify
Fnet= 3mAg(1-\mu)
because mB=3mA you can rephrase the above equation
Fnet= mBg(1-\mu)
so the acceleration of block B would be g(1-\mu), and plugging in the values I got the answer -4.34m/s2 rounded to three figures. This would also be the acceleration of block C.
Next I needed to find the time it took block C to hit the ground.
so
y = 1/2 at2
t = sqrt(2y/a)
t = sqrt(2*-1.05m/-4.34m/s2)
t = 0.695s rounded to three figures
Did I do this problem correctly? And if not, can you please show me the correct way of doing a problem like this? Thanks.
Now that I review my notes, I think I might have gotten this problem incorrect. Was I supposed to take the net force acting on block B and divide by the total mass of A + B + C to find the acceleration of the system?
It is better if you first draw the free-body diagram for all bodies, including the forces of tension in the ropes.
ehild
what have you meant is correct.
To find the acceleration , you have to divide by total mass as they are all connected by a string, therefore sharing same a
9K
