Three forces applied to a trunk
  • Thread starter Thread starter TS656577
    Applied Forces
The discussion revolves around calculating the net work done on a trunk subjected to three forces: F1 = 5.5 N, F2 = 8.7 N, and F3 = 2.6 N, while moving 2.8 m on a frictionless surface. The net work done by the forces is determined by summing the individual works, resulting in a total of 3.22 Joules. The gravitational force and normal force do not contribute to the work since their displacement is perpendicular to the direction of movement. Consequently, there is no net transfer of energy to or from the trunk, and the kinetic energy remains unchanged.
  • Understanding of Newton's laws of motion
  • Familiarity with work-energy principles
  • Knowledge of vector components and angles in physics
  • Basic proficiency in calculating work (W = Fd)
  • Study vector decomposition in force analysis
  • Learn about the work-energy theorem in detail
  • Explore examples of work done by multiple forces
  • Investigate the implications of frictionless surfaces on work calculations
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of work and energy concepts.
TS656577
The figure shows three forces applied to a trunk that moves leftward by 2.8 m over a frictionless floor. The force magnitudes are F1 = 5.5 N, F2 = 8.7 N, and F3 = 2.6 N, and the indicated angle is θ = 60°. (a) During the displacement, what is the net work done on the trunk by the three applied forces, the gravitational force, and the normal force? (b) Is there a net transfer of energy to or from the trunk? (c) Does the kinetic energy of the trunk increase or decrease?
W=Fd
I know that Force 1 did 15.4 J of work (5.5 times 2.8) and I know that Force 2 did -12.18J of work (dotted line = 4.35 and 4.35 times 2.8= 12.18) Force 3 didnt do any work on the block. I don't know how to tie it all together
D
There isn't sufficient information, where is the angle 'theta' measured from for example? A diagram or further explanation would be helpful.
oops...forgot to upload the diagram!
Okay, all your answers thus far are correct. For question (a) the net work done is simply the sum of all the work done by the individual forces. With respect to the work done by gravity and the normal force, you have to decide if there was any displacement that wasn't perpendicular to the direction of the normal force and the weight.
The solution to (b) follows directly from (a), positive work is energy in, negative work is energy out.
I'm sure you can figure out (c) yourself :smile:
The work due to normal force and gravitational force is 0. So is my answer 3.22
3.22 Joules. Correct :approve:.
THANKS! and i got the last two!
A pleasure, I hardly did any work :smile:
  • · Replies 56 ·
