Three point charges are arranged on a line.
In this discussion, the problem involves three point charges arranged linearly: q3 = +5.00nC at the origin, q2 = -4.00nC at x = 4.50cm, and an unknown charge q1 at x = 2.00cm. To determine the magnitude and sign of q1 such that the net force on q3 is zero, Coulomb's law is applied. The correct approach involves setting the forces exerted on q3 by q1 and q2 equal to each other, taking into account their respective distances from q3. The final formula derived for q1 is q1 = √[(q2)^2*(r1^2)/r2^2], where r1 and r2 are the distances from q1 and q2 to q3, respectively.
  • Coulomb's Law for electrostatic force calculations
  • Understanding of point charge interactions
  • Basic algebra for solving equations
  • Ability to interpret and create diagrams for physical problems
  • Study the implications of charge polarity on force direction in electrostatics
  • Learn how to apply Coulomb's Law in multi-charge systems
  • Explore the concept of electric field and its relation to forces on charges
  • Practice solving problems involving net forces on point charges
Students studying electrostatics, physics educators, and anyone interested in solving problems related to electric forces and charge interactions.
Mdhiggenz
Three point charges are arranged on a line. Charge q3 = +5.00nC and is at the origin. Charge q2 = -4.00nC and is at x = 4.50cm . Charge q1 is at x = 2.00cm.
What is q1 (magnitude and sign) if the net force on q3 is zero?
So first thing I did was draw a diagram where q3 was located at (0,0) q1 at (2.00cm,0) and q2 was located at (4.50cm,0)
Then after looking at the problem for a while I know I must use coulomb's law however since the net for q3 is 0 that threw me off a bit.
So what I decided to do was make two separate coulomb's law equations and equal them to each other.
(q1)^2/r^2=(q2)^2/r^2
Ultimately solving for q1 gives.
q1= √[(q2)^2*(r1^2)/r2^2]
Not sure if I'm on the right track just brainstorming, much help is appreciated
Higgenz
Why do you use the same r for (q1, q3) and (q2, q3)? What it should it really be in these two cases?
Wouldn't the distance for q3 be 0 since it is at (0,0)?
Only thing else I can think of is maybe getting the distance of Q1 and Q2 and possibly use Pythagoras theorem to get the total distance?
You need to find the forces on charge Q_3 due to charges Q_1 and Q_2. What does r in Coulombs Law actually represent?
You need the distance between q1 and q3 and between q2 and q3. They are all on the same line. You are given their distances from the beginning of the line. Moreover, q3 is at the beginning of the line. If you still can't figure it out, take a piece of paper and pencil and sketch it.
I would suggest drawing a diagram, showing the directions of the forces on Q_3 due to Q_1 and Q_2. Because you know the net force on Q_3 is 0, it should be quite obvious what direction the force on Q_3 due to Q_1 is and from this you can infer the polarity of Q_1.
10K
