Throwing a ball from a train at an angle
  • Level: Undergrad
  • Thread starter Thread starter Billyboy777
    Angle Ball Train
2 replies · 3K views · last reply
Billyboy777
Hi all, I've been trying to find an answer to this question for a while, (bear with me physics is not a strong point). I would like to know how one would go about calculating how fast you have to throw a ball out of a train to negate its forward momentum. My understanding is that if you throw the ball straight out of the back you just need to match the trains speed, but what happens if you throw the ball at a diagonal? If i considered straight out of the side of the train to be 90degrees and out the back to be zero degrees, does the ball need to be thrown harder to compensate for the shallower angle and if so by how much?
Yes you're quite right.
When you throw the ball at an angle, you can think of its motion as having two components - one in the direction the train is moving and one perpendicular to it, ie sideways.
And you want the component in the direction of the train to be exactly the opposite of the train's motion.
One way to see how fast this is for any direction, is to draw a scale diagram: draw an arrow backwards equal to the trains speed, then draw a line perpendicular until it meets the line of the ball's direction. Then the length of the line along the ball's direction tells you the speed you have to throw it. (I'll post a diagram as soon as I can do one.)
You can use a calculator and do some physics mumbo jumbo - just divide the speed of the train by the cosine of the angle you throw the ball and that's how fast you must throw it.
Vector diagram of a ball thrown from a train at an angle: a box labelled Train with a long backward arrow for train speed, a throw speed arrow at an angle to a perpendicular line of throw, and text giving the scale of 1 cm = 10 mph and the cosine calculation.
Amazing, thanks.
