Thrust needed for Orbit of a satellite
The discussion focuses on calculating the thrust required for a satellite to increase its orbital radius by a factor of 0.5 using a 500N thrust rocket. The satellite's weight is 200kg, and its initial speed is 500 km/hr. The participants highlight that a single burn is insufficient for this maneuver, as it requires two burns: the first to enter an elliptical orbit and the second to circularize at the new altitude. The Hohmann transfer method is mentioned as the most efficient way to transition between circular orbits, although it was noted that the participants had not been taught this concept.
  • Understanding of Newton's law of gravitation (F = Gm1m2/r^2)
  • Knowledge of orbital mechanics, specifically circular and elliptical orbits
  • Familiarity with the concept of delta-V in orbital maneuvers
  • Basic principles of momentum conservation (m1v1 + F*t = m1v2)
  • Research the Hohmann transfer method for orbital maneuvers
  • Study the relationship between orbital radius and velocity in circular orbits
  • Explore the calculations for energy differences in circular orbits
  • Learn about the implications of thrust duration on orbital changes
Aerospace engineers, physics students, and anyone involved in satellite mission planning or orbital mechanics will benefit from this discussion.
Kalus
A satellite is fitted with a station keeping rocket capable of producing thrust of 500N. Its speed is 500Km/hr. Mission control wishes to increase the radius of orbit by a factor of 0.5. For how long should the rocket be fired to achieve this? (The weight of the satellite and rocket is 200kg, neglect the weight of fuel used during the burn)
F= Gm1m2/r^2 (although m2 is not known)
F/m1 = Gm2/r^2
a= Gm2/r^2
a= V^2/r
so,
V^2/r = Gm2/r^2
V= root(Gm2/r)
also
m1v1 + F*t = m1v2
My idea was to try and find the velocity of orbit at 1.5r, but I am not sure how i can do that without using the mass of the body that the rocket is orbiting about. After that my idea was to use the above momentum formula and rearrange for t? Its really the calculation of the new velocity that I am stuck on.
The question, as written, is a bit ill-posed. Increase the radius of an orbit (implying circular orbits) requires two burns. The first burn places the vehicle in an elliptical orbit that brings the vehicle to the desired altitude. At some later time the vehicle will be at the desired altitude. The second burn takes place then and circularizes the orbit. The most efficient way of transferring from one circular orbit to another is the Hohmann transfer.
You don't need to know the mass of the planet.
Thanks for your input. We haven't been taught about the Hohmann transfer, so it is unlikely i need theory from it. The question assumes just one burn.
I've realized that from the equations I've listed below i can form:
V1^2 * r = V2^2 * 1.5r = G*m2
However, this suggests that the speed in the second case with a bigger radius will be higher? I thought it was the opposite of this?
That suggests the speed in the second case is lower. Whenever you have a relationship of the form xa*yb=constant, with a and b > 0, then increasing x means you have to decrease y.
Simply decreasing the vehicle's speed from the initial v1 to v2 will not achieve the desired goal. It will do just the opposite: It will send the vehicle into a lower orbit (more specifically, an elliptical orbit with a lower semi-major axis). A single burn of any sort will not achieve the desired goal.
Could you write the problem as stated in your text?
The way i have stated the problem is exactally how it is written in the text. The only other information given is 5 possible answers (its from a multiple choice past exam paper). It may assume a simplified situation (e.g. no elliptical orbits and one firing).
If we were to assume it could be done, using the parameters i listed in my first post how could you solve to find a V2 with the new radius 1.5r?
Many thanks, Andy
What is the difference in mechanical energy (kinetic plus potential) for an object in a circular orbit with radius r versus that for an object in a circular orbit with radius 1.5*r? Whatever that difference is, you will have to supply at least this much energy in terms of delta-V.
  • · Replies 26 ·
  • · Replies 62 ·
  • · Replies 16 ·
