Calculate Thrust of Rocket: Homework Statement
  • Thread starter Thread starter hk4491
    Rocket Thrust
The discussion focuses on calculating the thrust of a rocket with an initial mass of 30,000 kg, where 80% is fuel, burned at a rate of 200 kg/s, and expelled at a velocity of 1.8 km/s. The thrust is derived from the equation F = m * a, with a = vrel * (R / (m0 - Rt)) - g. A critical error identified involves mixing units, specifically adding kg/s to Newtons, indicating a mistake in the differentiation process. The discussion emphasizes the importance of unit consistency in physics calculations.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of rocket propulsion principles
  • Familiarity with calculus, particularly differentiation
  • Basic understanding of unit analysis in physics
  • Review the principles of rocket propulsion and thrust calculation
  • Study unit analysis and dimensional consistency in physics equations
  • Learn about the application of calculus in physics, specifically differentiation
  • Explore advanced topics in fluid dynamics related to rocket fuel expulsion
Students studying physics, aerospace engineers, and anyone involved in rocket design and propulsion analysis will benefit from this discussion.
hk4491
A rocket has an initial mass of m0 = 30,000 Kg, from which 80% is fuel. The fuel is being burned at a rate of R = 200 kg/s and the gas is expelled with a velocity of vrel = 1.8 km/s. The velocity of the rocket is calculated by:
v = vrel* ln \frac{m0}{m0 - Rt} - gt
Calculate:
(a) The thrust of the rocket
(b) The time until the rocket runs out of fuel
(c) The velocity of the rocket when the rocket runs out of fuel, under the condition that the rocket is always traveling perpendicullarly, and the g is always constant. Air resistance is negligble.
Hint: How does Newton's second law look like with a change of mass with respect to time?
F = m * a
a = \frac{dv}{dt}
\frac{dm}{dt} = m0 - Rt
After diffrentiating the given equation for velocity I got:
a = vrel \frac{R}{m0 - Rt} - g
and the mass relative to time is:
m(t) = m0 - Rt
from this I got:
F = ma = R - gm0 + gRt
This is where I got stuck. The question doesn't seem to ask for the thrust at a specific moment in time, yet the equation for force I got at the end still takes time into account. Did I do something wrong during differentiation?
The question asked for the thrust, and you're giving it the thrust!
So there is no problem.
EDIT:There is one problem though:
F=v_{rel}R-gm_0+gRt
Likes 1 person
hk4491 said:
from this I got:
You did something in multiplying m*a. Look at the units. *Always* look at the units. Your R has units of kg/s. The other two terms in ##R-gm_0+gRt## have units of kg·m/s2, or Newtons. You can't add a kg/s to a Newton. That you obtained these mixed up units means you made a mistake.
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 30 ·
