TI-30X Pro - Decimals Rounding issue
  • Context: Calculators
  • Thread starter Thread starter Sakitumi
12 replies · 5K views
Sakitumi
Hi guys,
I am using a Texas Instruments TI-30X Pro calculator.
I add 599,944,263.55 to 8,404,167.32 and get 608,348,430.9 instead of 608,348,430.87. It seems it rounds the decimals on its own.
What am I missing?
Thanks i advance for your answers and help!
Isn't the display limited to 10 digits? In that case, then it will indeed round the result to 10 digits.
Thank you for your reply.
Now I quote from the User Manual that came with the product:
[poly solv] An entry or menu displays beyond 16 digits.
I asume it should display the result without rounding it.
I guess the limit in digits display goes beyond the 10 digit you normally find in so called market calculators.
DrClaude said:
What is the answer to ##\sqrt{3}##?
1.732050808
Sakitumi said:
1.732050808
So the calculator is indeed rounding to 10 digits (##\sqrt{3} = 1.732\,050\,807\,568\,877\ldots##)
Then in my hundreds of millions arithmetic I should get Syntax Error or similar error considering the, I quote:
EQUATION LENGTH ERROR — An entry exceeds the digit
limits (80 for stat entries or 47 for constant entries); for
example, combining an entry with a constant that exceeds the
limit.
I am confident I am doing something wrong. I tried the same calculation on a Chinese simple calculator and it works perfectly fine. The price and brand comparison is no match and not the subject to my inquiry.
But probably you are right and the producer missed filling the "10 digit limit" information in the User's Manual.
Internally, the calculator is probably keeping more digits than the 10. After having got the result for ##\sqrt{3}##, you can multiply it by 2, and you will probably find a number ending in 5, not in 6.
limit.
I am not sure what you are doing, but it looks like you are entering something that is too long. Check what you are actually typing on the keypad.
I quote from the User Manual:
limit.
It should display pass by the 10 digit limit, shouldn't it? Instead it rounds it.
limit.
The way I read, is that if you try to enter a constant with more than 47 digits, it will not take it. I would be extremely surprised if the calculator could actual do calculations on a 47-digit number. My guess is that internally, it must use 12-16 digits at most.
Thank you guys! I need a new calculator then.
