Time and the Sound Barrier: How Fast is Too Fast?
  • Context: Graduate
  • Thread starter Thread starter Tjl
    Barrier Sound Time
The discussion revolves around the concepts of sound and light barriers, particularly focusing on the implications of exceeding these limits in relation to time. Participants explore theoretical scenarios regarding the behavior of sound and light when an object travels faster than these barriers, as well as the nature of time in such contexts.
  • Some participants suggest that if an object exceeds the sound barrier, sounds would lag behind, and they question whether a similar effect occurs with light and time.
  • Others argue that according to relativity, it is impossible to exceed the speed of light, citing the relativistic addition of velocities as evidence.
  • One participant expresses confusion about the notion of moving faster through time than time itself, indicating that while relativity allows for changes in "speed through time," it does not imply that time itself can be exceeded.
  • There are discussions about the theoretical existence of tachyons, with some participants asserting that faster-than-light travel or communication cannot be disproved until a credible theory is established.
  • One participant emphasizes that the effects of sound lag are relative and can occur at various speeds, not just near the speed of light.
  • Another participant clarifies that in a tachyon's reference frame, light would still be observed moving at the speed of light, despite the tachyon's faster speed.
Participants do not reach a consensus on the implications of exceeding sound and light barriers, with multiple competing views on the nature of time, tachyons, and the relativity of motion. The discussion remains unresolved regarding the theoretical aspects of faster-than-light phenomena.
Limitations include the speculative nature of tachyons and the varying interpretations of relativistic effects at different speeds. The discussion reflects a range of assumptions and definitions that are not universally agreed upon.
Tjl
When an object breaks the sound barrier, sounds "lag" behind that object as it travels faster, theoretically the same can be said for light. Would this work the same for time? If you exceeded whatever limit this barrier has would time "lag" behind you?
No, you cannot pass the speed of light. There are a number of ways to show this, possibly the most relevant in this case is the relativistic addition of velocities:v_{AC}=\frac{v_{AB}+v_{BC}}{1+\frac{v_{AB}v_{BC}}{c^2}}. From this, you can see that any time you add two speeds which are less than the speed of light, the result will always be less than the speed of light.
I'm confused about what you're asking. Are you proposing moving faster through time than time itself? Relativity allows you to change your "speed through time" (which can be quite a confusing phrase) with respect to other observers, but time for you still continues on as normal.
it would certainly do, but unlike u(tjl) said. it is relative so one observer/listener at the end of a train and next at the head(i don't know what u call the place where the driver;if there is one; sits in the train) of the train can hear the sound of "a" gun shot at different times! may be this is it. if not, i don't know.
regards
gurkha-war-horse
It was purely theoretical, and not to dispute, but your statement is incorrect. Nobody knows if tachyons do in fact exist, and until a credible theory can be raised, faster then light travel or communication cannot be disproved.
regards
gurkha-war-horse
Also, that is only taken into effect if the train was moving at near the speed of light.
You asked a question about physics, and you got the answer according to physics. According to physics, there are no tachyons.
There are also no unicorns. :smile:
I did not say tachyons do not move faster than the speed of light if they exist. I said you cannot move faster than the speed of light; you are not composed of tachyons.
I slipped the word you in there :( That is my mistake sorry. I meant any object or particle or tachyon.
NO!
it is actually at all motions (ofcourse relative) but is much effective at high speed(ie. not only at 0.99c/near the speed of light). But u can't deny that it happens even in lower ones.
:-p :-p :cry: :devil: :eek: :-p
let me remind u what DrChinese said/wrote "there are no unicorns". :smile:
gurkha-war-horse
Well then, hypothetically speaking, if you're asking if light "lags" behind a tachyon in a tachyon's own reference frame, the answer is still no. A tachyon will still see a light beam as moving at c. This follows naturally from the second postulate of special relativity, but to reemphasize the point we can solve the relativistic addition of velocities equation (in relativistic units) v_{AC}=\frac{v_{AB}+v_{BC}}{1+v_{AB}v_{BC}} for a tachyon (A) which has velocity v_{BA}=3 relative to some standard matter particle (B). From the tachyon's reference frame (if I am allowed to do such things; I haven't read much about tachyons, so corrections may be needed) particle B will have velocity v_{AB}=-3, and of course a photon (C) in particle B's reference frame will have v_{BC}=1, so in the tachyon's (A's) reference frame, the photon (C) will have velocity v_{AC}=\frac{-3+1}{1-3}=1.
  • · Replies 25 ·
  • · Replies 36 ·
  • · Replies 33 ·
  • · Replies 21 ·
