Time dependent expectation value problems
19 replies · 3K views · last reply
BREAD
Problem text: spin 1/2 particle in field B = B0 x-hat, Hamiltonian H = -(e/m_e) S·B, initial state |S_z = +hbar/2> at t=0; parts (a) and (b) ask for expectation values of S_z measurements at times T2 and after a measurement at T1.
I tried to solve (a), but i don't know which approach is right ((1) or (2)) and how to solve (b).[/B]
Handwritten derivation of a spin measurement: |+> evolves under T2 to e^(-iET2/hbar)|+>, then S2 state 1/sqrt2(|+>+|->) gives probability |1/sqrt2(...)|^2 = 1/2, and the result +hbar/2 times 1/2 equals hbar/4.
  • Handwritten derivation for part (a): e^(-i E T2/hbar) applied to |+>, a bra-ket expectation with S_z(+/-) giving a column matrix of hbar/2 entries, then the S_x state (1/sqrt2)(|+> + |->) yielding probability 1/2, and a final value of hbar/4.
You don't start the problem correctly. The ##|S_z = + \hbar/2 \rangle## state is not an eigenstate of the Hamiltonian, so after a time ##T_2##, the state of the system is not ##e^{-i E T_2 / \hbar} |S_z = + \hbar/2 \rangle##.
H=-(e/mc)S * B , Sz and H differ just by a multiplicative constant, so they commute. The Sz eigenstates are also energy eigenstates.
(* I tried to solve it Sz not Sx by mistake)
In which direction is the magnetic field?
In the problem, megnetic field is Bx direction.
So how can you rewrite ##\mathbf{S} \cdot \mathbf{B}##?
Sx * B
So no commuting with ##{\bf S}_z## !
Then how can i solve this problem. i would appreciate it if you can help me
You have to express the initial state in terms of the eigenstates of the Hamiltonian.
Handwritten notes on spin physics: H = -(e/mc) SxB, Sx eigenvalues ±ħ/2 with eigenstates (1/√2)(1,1) and (1/√2)(1,-1), H eigenvalues ∓Bħe/2mc, initial state |Sz=+ħ/2> = |+>, and the Sx(H) eigenstates (1/√2)(|+>+|->) and (1/√2)(|+>-|->).
I think it is not. Sx and H have same eigenstates, so the initial state l+> is lSx+> + lSx->
Don't forget the normalization factor.
But now that the state is expressed in terms of the eigenstates of the Hamiltonian, it should be easy to calculate the time evolution.
Screenshot of a Korean web page notice on a brown background reading "삭제된 이미지입니다." (This image has been deleted), with a footer message "회원가입없이 사진을 공유하세요." (Share photos without signing up) and the watermark "길횟네 이미지 창고".
I think the answer is weird. These are the probability for Sz + , and 1-cos(T2/h)(E1-E2) for Sz -
So, the expectation value h/2(1+cos(T2/h)(E1-E2)) and -h/2(1-cos(T2/h)(E1-E2)) respectively
Why? This is a very standard problem in QM and illustrates nicely the concept of precession.
I replied the answer that i tried
Ok, I had replied before you posted the solution.
There is a problem, as you can clearly see that the prbability you get ranges from 0 to 2. Check again how you calculate the absolute value squared.
I got it, then how can i approach problem(b) i think the result of first measurement is same with (a)
The probability of measuring Sz = +ħ/2 is indeed given by the same equation, replacing T2 by T1. But you already know the measurement result, so you need to figure out what you get at T2.
By the way, you can simplify the result you get using explicit values for E1 and E2.
Result of first measurement at T1 is the same with (a). I should have to get a probability of that state before i get a expectation value as i did in (a).
I think total result probability is probability(T1) * probability(T2)
Screenshot of a Korean web placeholder on a brown background reading 삭제된 이미지입니다 (deleted image), with a footer in Korean reading 회원가입없이 사진을 공유하세요 (share photos without signing up) and the site name 길혜넷 이미지 창고.
Answer is quite complex, is it right??
