Time dilation for two observers in relative motion
  • Context: Undergrad
  • Thread starter Thread starter Raytele
    Relativity Time
10 replies · 2K views
Raytele
If time dilates differently for two observers in relative motion, how is this possible when both observers can claim that it is the other's time that is passing more slowly? Doesn't this create a contradiction? And how does the famous twin paradox explain or complicate this issue?
on Phys.org
Frames in relative motion don't agree what "at the same time as I stopped my clock" means. So you and I can zero our clocks when we pass and stop them some agreed time later and say the other's clock ticked slowly, but I say you stopped your clock late and you say I did. It's called the relativity of simultaneity.
The twin paradox is a different situation because one twin turns around. They can't both use "his clock ticks slowly", because that simple statement contains an assumption that the one making it has not accelerated, but the twin who returns has accelerated.
Reply
The twin paradox is not a paradox when properly analyzed. It only becomes a paradox if we make the mistake of incorrectly applying the time dilation formula and erroneously conclude that something is wrong because traveler sees earth twin's clock running slow so earth twin should be younger, earth twin sees traveler's clock running slow so traveler should be younger. But when we analyze it properly the apparent contradiction disappears: the traveler is aged less when the twins reunite, and this has nothing to do with time dilation.
So the twin paradox neither explains nor complicates the issue - it's just not relevant to your question. For more about it, check out the sticky thread at the top of this forum: https://www.physicsforums.com/threads/when-discussing-the-twin-paradox-read-this-first.1048697/
The key your question about the apparent contradiction in time dilation (you say my clock is running slower than yours, I say your clock is running slower than mine, we're somehow both right) is explained as @Ibix says above by the relativity of simultaneity. For a more detailed explanation, try https://www.physicsforums.com/threads/time-the-special-theory-of-relativity.846242/#post-5307390 or https://www.physicsforums.com/threa...on-question-w-spaceships.883303/#post-5552719
Reply
If two people walk away from each other, they both look smaller relative to the other. Each might say that eventually the other is only about as big as his or her own thumb.
The lesson is that relying on a superficial analysis is not sufficient. Many things might appear contradictory at first sight. You always have to think things through.
Reply
Thank you very much to everyone who responded, you were able to help me understand this fabulous and complex topic.
Einstein is said to have claimed that the resolution of this dilemma occurred to him while in bed, causing him to sit upright. It's the relativity of simultaneity that makes it possible.
