Undergrad Is Time Dilation Just a Misunderstanding of Clock Errors?
Time dilation is often misunderstood as a mere clock error, but it is a well-established consequence of special relativity. The discussion highlights misconceptions about time running slower in stronger gravitational fields and the implications of the twins paradox. It emphasizes the importance of using reliable sources, such as textbooks and peer-reviewed papers, for understanding complex physics concepts. The moderators suggest starting from foundational materials to grasp the principles of time dilation accurately. Overall, the thread concludes that misconceptions about time dilation stem from misinterpretation of physics rather than actual errors in the concept itself.
paul1365
TL;DR
Why are atomic clocks regarded as a constant by some?
According to a video I watched recently 'time' allegedly runs a tad slower in places on the Earth where the magnetic field is stronger. No doubt that has been tested and confirmed by atomic clock experiments.. to my simple mind that just suggests a timing error caused by the difference in gravitational strength causes the clock to run slower rather than time itself, in which case atomic clocks should merely include a gravimeter to measure the gravity at the clocks location to offset the error rather than it leading to such fantastical notions of time travel.
The twins paradox is also widely accepted as fact. but I've always struggled with that notion, I suspect a similar error caused by the speed of the object containing the atomic clock causes the photons being measured to have to travel a longer path and because the speed of light is fixed the photons have to slow down... but according to everyone this somehow equates to time itself slowing down rather than it being clock error.
For me this 'dilation' is just error and physicists...(or maybe its just the documentary producers) are looking at it from the wrong angle but I'm just an average Joe... can someone try and explain to me why I'm wrong in laymans terms?
TIA.
  • Sad
Likes PeroK
Time dilation is derived using ideal perfectly functioning clocks - look up the light clock. Atomic clocks were not invented when relativity was first developed.
And if you look at it in terms of geometry, time dilation is just the same as the distance between two flat planes depending on whether you measure the perpendicular distance or the distance at an angle. It's not very mysterious, just not something you encounter at low speed.
Thread closed for Moderation...
Time dilation is hardly a "clock error". As @Ibix stated, it is a consequence of special relativity that has been well-established for quite some time. Same for the Twin "Paradox".
This thread will remain closed.
This is not a good way to learn physics. You need to be looking at textbooks or peer-reviewed papers.
No, because, in the words of Wolfgang Pauli, you are not even wrong. You are not learning from good sources, and you are misinterpreting the information you are getting, and this is leading you to form personal theories (which are off limits for PF discussion anyway) that are too far off the mark to even be corrected.
Your best bet at this point would be to forget everything you think you know about time dilation and relativity, and start from scratch learning from a good textbook. Taylor & Wheeler's Spacetime Physics is a good textbook on special relativity. Sean Carroll's online lecture notes on General Relativity are a good introduction to both special and general relativity. Both of those sources include discussions of time dilation, although the Taylor & Wheeler textbook, IIRC, only discusses time dilation due to relative motion, whereas Carroll also discusses time dilation in a gravitational field, which you also mention.
If you have further questions after spending some time with valid sources such as the above, by all means post a new thread with your questions. But in the meantime, this thread will remain closed as we do not even have a valid basis for discussion.
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 58 ·
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 58 ·
  • · Replies 34 ·
