Time Dilation: If You Go to Space, What Happens to Time?
Time dilation occurs when one observer travels at a significant fraction of the speed of light while another remains stationary, leading to different aging rates. If the traveling observer moves at 0.8c, for instance, they would age less than the stationary observer due to the effects of relativity. The discussion also highlights that reaching the speed of light is impossible for massive objects, and at light speed, time does not pass for the traveler. The concept of simultaneity is relative, meaning events can appear simultaneous in one frame but not in another. Overall, the complexities of time measurement in different reference frames raise questions about the applicability of traditional time concepts to massless particles like photons.
fire100_anand
If two persons are wearing the same watch showing the same time say 5 Am...one person remains in Earth and the other person goes to space at the speed of light ...After one hour the watch on person on Earth will show..what will be the time on the watch worn by the person who went to space...please explain time dilation
It's impossible for any observer to reach the speed of light in relativity. But suppose someone is on a ship which moves away from the Earth at some speed v that's smaller than c (c is the speed of light), and then turns around and returns to Earth at the same speed v. In this case, if the person on Earth has aged by some amount T between the time the ship left and returned, then the person on the ship will only have aged by a smaller amount T * \sqrt{1 - v^2/c^2}. For example, if the person on Earth aged 10 years, and the ship was moving at 0.8c (80% the speed of light), then the person on the ship will have only aged by 10*\sqrt{1 - 0.8^2} = 10*\sqrt{0.36} = 10*0.6 = 6 years.
As an alternative reply, if one uses continuity, one can argue that objects traveling at the speed of light do not experience any passage of time, so omitting the impossibility of a massive object accelerating to the speed of light, they will read their time as 5AM, no matter what time the person left back on Earth reads.
Can you use continuity?
If so, can you show this explicitly?
This is just assuming that the equation t' = t*(1-v2)1/2 holds when |v| = 1 (geometrized units) where v is the velocity of the primed frame as measured by the unprimed frame. Note how it doesn't make sense to input a non-zero t' and be able to solve for a t when |v|=1, even if we allow complex numbers.
You see, it seems to me that:
given two distinct events P and Q on a photon's worldline,
either P is to the future of Q, or vice versa.
So, I question whether time-measurements by massive particles (and conclusions drawn from them) can be applied in the massless case.
Given two events P and Q, it is not at all necessary for one to be in the future light cone of the other (the interval may be space-like, not time-like. Indeed, the third possibility is that the events are light-like, which is the case since they are connected by the worldline of a photon). Photons, as measured from our reference frame, have future and past events with respect to our reference frame. As we know from our study of relativity, simultaneity is relative to each reference frame. It may just be the case that all events are simultaneous as measured from the frame of a photon.
Indeed, the idea of measurements *in* the frame of a photon is rather silly, but the interpretation of time in that frame is so common that it would be an omission to leave it unmentioned. :)
Yup.
Causality is a relation between events, regardless of any choice of reference frame.
Well... one needs definitions to make things work.
I know of no consistent set of definitions that will extend the notion of a massive particle's reference frame that of a photon.
Here's my earlier post on this matter:
https://www.physicsforums.com/showthread.php?p=899778#post899778 (#17)
  • · Replies 65 ·
11K
  • · Replies 23 ·
  • · Replies 46 ·
