Time for light pass through glass
  • Thread starter Thread starter badd99
    Glass Light Time
badd99
SOLVED!
Thank you!
looks right to me *shrug*
Im completely lost how this is not right. The first answer is right for sure.
Draw a picture of the trajectory. Label the angles. Are you sure that the sine function is the appropriate choice?
oops was cosine. Thank you!
