Dravish
- 6
- 0
From my understanding of GR, time and gravity were shown to be essentially the same thing, is that the generally accepted interpretation in contemporary physics?
Dravish said:From my understanding of GR, time and gravity were shown to be essentially the same thing, is that the generally accepted interpretation in contemporary physics?
Robert J. Grave said:Mass/energy and space/time together is the universe. They cannot exist separately. The shape of space/time is related to the mass in it. All aspects of space/time are altered by this shape change. Three spatial and one time dimension. This effect is the gravitational effect. The more accute the bending or distoting of space/time the more pronounced the effects are. The black hole discriptions speaks of time stopping inside it.
This is the extream of space/time warping on to it's self. - Robert
jimbobjames said:Of course it is still interesting to consider why it is that clocks at different points in the field tick at dfferent rates - does anyone out there actually understand why this is? Does a deeper study of GR or String Theory or QFT provide the answer? (Id prefer to know up front so I can optimize my time usage!).
(To say the answer is simply "spacetime curvature" would be circular, because different clock rates at different places is curvature of the time part of spacetime).
MeJennifer said:Unruh, in http://arxiv.org/PS_cache/gr-qc/pdf/9312/9312027v2.pdf" juxtaposes time in GR and time in Quantum mechanics.
In GR there is no background, particles do not live in spacetime they make spacetime, in other words, time and space are emergent properties of the gravitational field.
I think it was Einstein who said it best when he said in Nature (Feb. 17, 1921, p. 783)Dravish said:From my understanding of GR, time and gravity were shown to be essentially the same thing, is that the generally accepted interpretation in contemporary physics?
..., in respect to its role in the equations of physics, though not with regard to its physical significance, time is equivalent to the space co-ordinates (apart from the relations of reality).
jimbobjames said:Thats a good analogy, Pervect. Cheers.
The real physical time is the one on the watch, regardless of the coordinate system you choose to set up. Right.
"A second really is a second no matter where you go":
But the real rate of ticking really is different at different heights in the field, since if I bring those watches back to the same place later, the watch readings differ (regardless of coordinate choice). The relative number of physical ticks on the watches at different heights, which you can measure and compare when you reunite the watches, is different (and is independent of coordinate choice). And so one real second for me might correspond to 2 real seconds for you, it depends on our relative paths through spacetime. Or am I wrong about this?
I'd love to see a picture of the 2-d projection of the 4-d spacetime in the spherically symmetric (but weak) field near a planet. The 2 dimensions would be the radial (or height) and (coordinate-) time dimensions.
Geodesics on that curved 2-d surface - assuming the curvature to be the time curvature only - would show what we perceive as objects falling from large r to small r. What shape is that surface - can it be embedded into a flat 3-d space?
Have you - has anyone here - ever come across a visualization like that? I'm sure it would help me understand the analogy the relationship between gravity and time even better.
Spacetime is the combined gravitational field of all particles.intel said:If this is so - particles make spacetime. Then what makes the gravitational field? I believed large masses were their cause, but small particles make big masses - so it still leaves what makes the gravitational field?
MeJennifer said:...time and space are emergent properties of the gravitational field...
I'm not sure what you're doing here.If we were to assume that the equator represents the coordinate time axis, and the zero degree line of longitude were to represent a spatial coordinate, h say (for height), then the metric is diagonal with -1 and sine^2 (t) - right?
Coordinate Time (t) along the equator corresponding to theta (because the radius is 1) and spatial height (h) going from the equator to the north pole. 1 space and 1 time dimension.
Dravish said:To quote from ‘Time, Gravity and Quantum Mechanics, by W. G. Unruh’;
“A more accurate way of summarizing the lessons of General Relativity is that gravity does not cause time to run differently in different places (e.g., faster far from the Earth than near it). Gravity is the unequable flow of time from place to place.
Dravish said:It seems that perhaps gravity and time should be equated
Dravish said:I am trying to put together a paper using this perspective
intel said:Can I take this and say that spacetime, space and time are the direct result of particles or any matter which came into existence at t=0, the big bang?
