Cogswell
- 54
Prove the following theorum:
The time-independent wave function ## \psi (x) ## can always be taken to be real (unlike ##\Psi (x,t) ##, which is necessarily complex). This doesn't mean that every solution to the time independent Schrodinger equation is real; what it says is that if you've got one that is not, it can always be expressed as a linear combination of solutions (with the same energy) that are. So you might as well stick to ## \psi## 's that are real.
Hint: If ## \psi(x)## satisfies equation [1.0], for a give E, so too does its complex conjugate, and hence also the real linear combinations ##( \psi + \psi ^*)## and ##i( \psi - \psi ^*)##
Equation [1.0]:
E \psi = -\dfrac{\hbar ^2}{2m} \dfrac{d^2 \psi}{dx^2} + V \psi
I don't fully get what it. So it's saying that if I have a ## \psi (x) ## that is a complex function of x, then that can somehow be expressed in the form:
## \psi_{complex} (x) = \psi_1 (x) + \psi_2 (x) + \psi_3 (x) ...##
How does that work? I also don't know how to incorporate the hint into it.
(Sorry quantum mechanics isn't my strong point so it would help if you explained it to me in simple terms)
