Time translation invariant equation
The equation ∂E/∂t = t∇ × E is shown to be not invariant under time translations, as demonstrated through the transformation E_T(t, x) = E(x, t - T). The analysis reveals that if E(x, t) is a solution, then E_T(t, x) cannot satisfy the original equation unless T = 0. Additionally, the equation exhibits invariance under spatial translations, indicating conservation of linear momentum, but not energy. The discussion emphasizes the importance of clarity in mathematical reasoning and step-by-step validation.
  • Understanding of vector calculus, specifically curl and divergence.
  • Familiarity with partial differential equations and their solutions.
  • Knowledge of invariance principles in physics, particularly in relation to symmetries.
  • Proficiency in using the chain rule for differentiation in multivariable calculus.
  • Study the implications of time translation invariance in physical systems.
  • Explore the concept of symmetries in differential equations and their physical interpretations.
  • Learn about conservation laws related to spatial translation invariance.
  • Investigate the role of the curl operator in electromagnetism and fluid dynamics.
Students and researchers in physics and applied mathematics, particularly those focusing on differential equations, symmetries, and conservation laws in physical systems.
fluidistic
I must show that the equation ##\frac{\partial E}{\partial t}=t\nabla \times E## is invariant under time translations and I must also find its symmetries if it has any. Where E is a function of time and position.
Already given.
I assume that ##\vec E (\vec x ,t)## is a solution of the equation ##\frac{\partial \vec E (\vec x ,t)}{\partial t}=t\vec \nabla \times \vec E (\vec x , t)##.
I want to show that ##\vec E _T (\vec x , t)=\vec E (\vec x , t-T)=\vec E(\vec x , u)## is not a solution of the equation ##\frac{\partial \vec E _T (\vec x ,t)}{\partial t}=t\vec \nabla \times \vec E_T (\vec x , t)##
Let's go:
##\frac{\partial \vec E_T(t,\vec x )}{\partial t}=\frac{\partial \vec E_T(u, \vec x )}{\partial t}=\frac{\partial u}{\partial t} \cdot \frac{\partial \vec E ( u , \vec x)}{\partial t}=\frac{\partial \vec E ( u , \vec x)}{\partial t}=u \vec \nabla \times \vec E (u , \vec x )=u \vec \nabla \times \vec E_T (\vec x , t)=(t-T) \vec \nabla \times \vec E_T (\vec x , t) \neq t\vec \nabla \times \vec E_T (\vec x , t)##.
Is what I've done okay/valid?
For the symmetries, I guess I must check out if it has a translational invariance and/or rotation invariance.
Edit: I checked out and if I didn't make any error the equation is invariant under space translation. I think this means that if the equation represents a physical system then the linear momentum is conserved, but since it isn't time invariant, the energy isn't conserved. I'd have to check out if it's invariant under rotations...
I think you probably understand what you are meant to do. But the way you have written the answer is really confusing as to which step you are doing and why. And yeah, I'd guess you are meant to check for spatial translation and rotation. Maybe rotations around the origin is enough.
Thanks for the feedback. Could you tell me please which steps (all?) are confusing and/or how would you do it? Maybe it will make me understand something that I don't currently.
well, you do the entire thing in one line. But the order of logic seems weird to me. Mathematically it is right. But instead you could use several lines (one for each equality) and you could write why you can say that the two things are equal. This would make it easier to follow.
I see, thanks.
Let ##u=t-T##. I define ##\vec E _T (t, \vec x )=\vec E (t-T, \vec x)##. So that ##\vec E_T (t, \vec x)=\vec E(u, \vec x)##.
I want to see whether ##\vec E _T(t, \vec x )## is a solution to the equation ##\frac{\partial \vec E _T(\vec x ,t)}{\partial t}=t\vec \nabla \times \vec E _T (\vec x , t)##. If it is, then the equation is invariant under time translations. If it is not a solution, then it's not invariant under time translations.
I start with the left hand side of the equation: ##\frac{\partial \vec E _T(\vec x ,t)}{\partial t}=\frac{\partial \vec E (u, \vec x) }{\partial t}##.
Using the chain rule (I believe?), I can rewrite the last expression as ##\frac{\partial u}{\partial t} \frac{\partial \vec E (u, \vec x )}{\partial u}##. But looking at the definition of u, it is easy to see that ##\frac{\partial u}{\partial t}=1##. Thus, one reaches that ##\frac{\partial \vec E _T(\vec x ,t)}{\partial t}=\frac{\partial \vec E (u,\vec x)}{\partial u}##.
Now I use the equation given in the problem statement (considering t as a dummy variable), so I can write the right hand side of the last equation as ##u \vec \nabla \times \vec E (u, \vec x )## (I can do this because ##\vec E (\vec x , t)## is a solution to the equation given in the problem statement).
Replacing back u by t-T, I reach that ##\frac{\partial \vec E _T (t, \vec x) }{\partial t}=(t-T) \vec \nabla \times \vec E (t-T, \vec x) ## This is true because the curl acts on the spatial coordinates, not on time.
And so ##\frac{\partial \vec E _T (t, \vec x) }{\partial t}=(t-T) \vec \nabla \times \vec E _T (t, \vec x)##.
Therefore, if ##\vec E (\vec x ,t)## is a solution to the equation ##\frac{\partial \vec E (\vec x ,t)}{\partial t}=t\vec \nabla \times \vec E (\vec x , t)##, then ##\vec E _T (t , \vec x )## is a solution to the equation ##\vec E _T (t , \vec x )=(t-T) \vec \nabla \times \vec E_T (\vec x , t)##.
Thus ##\vec E _T (t , \vec x )## cannot be a solution to the equation ##\frac{\partial \vec E _T(\vec x ,t)}{\partial t}=t\vec \nabla \times \vec E _T (\vec x , t)## unless that ##T=0##.
So that the equation is not invariant under time translations.
What do you think now?
excellent :) nice and clear to read. also, I agree with the method and answer.
  • · Replies 32 ·
