Tinkercard Digital object and 3D printing
The discussion revolves around the creation and printing of 3D objects using Tinkercad, specifically addressing the smoothness of printed surfaces, the implications of floating objects in the design, and the behavior of objects that intersect the workplane during the 3D printing process.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant questions whether a sphere designed in Tinkercad, which appears meshy, will have a smoother surface when 3D printed.
  • Another participant asserts that printed objects will reflect the models on-screen, noting that the smoothness depends on scale and residue from printing.
  • Concerns are raised about the implications of floating objects in Tinkercad and whether they will print correctly, with one participant sharing their experience of printing floating objects successfully after exporting.
  • Further inquiries are made about objects that intersect the workplane, specifically if a sphere half above and half below the workplane would result in only the upper portion being printed.
  • Clarifications are sought regarding the term "printing directly" from Tinkercad, with some participants expressing uncertainty about the process and suggesting that models created in dedicated 3D printing programs might differ from those in traditional modeling software.
Participants express varying opinions on the effects of floating designs and intersecting objects, with no consensus reached on the implications of these design choices for 3D printing outcomes.
Participants mention the need for testing intersecting objects and the potential differences in model complexity between Tinkercad and other 3D modeling programs, indicating that assumptions about printing behavior may depend on specific circumstances.
fog37
TL;DR
Tinkercad digital object and 3D printing
Hello,
When creating a curved object in Tinkercad, something like a sphere, the spheres' surface does not look very smooth but rather meshy under close inspection. Will the 3D printed version of that sphere designed in Tinkercad have a smoother surface than the meshy surface it has in the software?
I think there is a distinction between 3D modeling softwares (like Sketchup) and 3D CAD softwares (like Fusion360).When compared with CAD softwares, can 3D modeling softwares create smoother and curvier digital objects which can then become smooth printed object?
Thanks!
Computer science news on Phys.org
I've printed objects from TinkerCad before and they will be printed accurate to the models on-screen, just as any other objects from other programs. It largely depends on the residue that is created, and the scale.
Smaller scale is generally less polygonal but with more noticeable residue, vice-versa for larger scale.
If you want a printed item to be smooth, you could always sand it!
Thank you.
What if the object is floating, i.e. it does not touch the TC workplane?
What if the digital object crossed the workplane with some portion of it being under the workplane itself? would the 3D print still be ok?
Thanks!
fog37 said:
Thank you.
Thanks!
You're welcome!
I only printed "floating" objects after exporting format... and that was fine; it basically printed the object alone, without heeding the space between the workplane. Not sure if printing directly will make a difference. As for spaces between portions of the object (ex. extra floating objects) I believe it can still print, but may have printed portions between the parts. In regards to that latter section I discussed, I only saw it happen once as I was recommended to print such parts separately if needed. And I'd recommend others do the same. Overall though, spaces shouldn't be too big of a worry if the objects are exported :) the 3D printing program can generally take care of that
Thank you. So it should not make a difference if the TC design is floating about the workplane. Saving the floating design as STL and pass it to the slicing software, then to the 3D printer is not an issue.
As far as the object "crossing"/intersecting the workplane, I meant, for example, a sphere that is half above the workplane and half below the workplane and wondered if, after saving that design as STL, etc. the 3D printer would only print the the top portion of the object...
What do you mean when you say "printing directly"? Directly from TC? Is that possible? TC is not a slicer...
I converted 3D models to .X or .OBJ format. I meant "directly" as in creating it from a 3D printing program (which I have never done but apparently exists. Seems like the models created there won't be complicated as those created in traditional modeling programs)
And I'd recommend testing those intersecting objects...I have no experience with them either. Good luck!
