Toboggan kinetic energy with pulling force at different angles
10 replies · 2K views
jasonbans
A toboggan is initially moving at a constant velocity along a snowy horizontal
surface where friction is negligible. When a pulling force is applied parallel to
the ground over a certain distance, the kinetic energy increases by 47%. By what
percentage would the kinetic energy have changed if the pulling force had been
at an angle of 38° above the horizontal?
w= Fd cos theta
w= 1/2mv^2
so Ek = 1.47 Ek intial Ek = kinetic energy
First find an expression for the change in KE when the force is applied along the horizontal.
you mean a expression for both cases?
we know that in the first case the force and displacement act in the same direction meaning no work is done.
and the second case i don't get, how can you get W = (Fcos38)d where F and d is not even given
Work is done in BOTH cases. This work results in an increase in KE.
No more numerical data is necessary. Just assume initial velocity is u in both cases and final is V for the first case and v for the second (symbols chosen so that big V is for the greater value and small v for the smaller value - I hate to call them v1 and v2!) since the final will be different for the two cases.
how am i suppose to find the velocity if they give so little information?
Assume that applied force is F in first case and Fcos38 in the second case.
Initial velocity is u in both.
Distance traveled is assumed to be constant e.g. x in both.
grzz said:
What is V in terms of u, x and acceleration?
i did this instead , this should make sense right? cause the change in W = the final kinetic energy - the intial kinetic energy, and W = Fd in first case and second is W=fdcos38
