Today Special Relativity dies
529 replies · 47K views · last reply
i told you i was investigating into it
i told you i was waiting on more conclusive data to make real conclusions
maybe you need to calm down :D
Oy - not only is every physicist wrong, but every mathematician is wrong too? Ram, you have a problem that we can't help you with here.
an expected response from someone indoctrined to believe...
so i opened up 3dsMax and started messing with spheres to try and figure out geometrically how GPS would work.
with one sphere and the earth, you can't really tell very much, basically the only information gleaned is that you're on the part of the Earth within direct line of sight with the satellite.
with two spheres, the intersection is a circle, more importantly where it intersects the Earth would be a line.
with 3 spheres you get a line, more importantly where that line intersects the Earth would be a point.
i'm assuming the fourth satellite <sphere> is for discerning altitude (but not really as it is a point on the line and the line might be coming in non vertical)
in each case time would be determined for each satellite, probably encoded into the pulse data. they run the time data from the satellites to generate 4 expanding spheres, the point where they all intersect gets the "you are here"
i think what that guy said about the fourth satellite being used for SR correction is false. just by messing with the sphere myself it doesn't seem to be the case.
just so you don't mistake me I'm not saying they DON'T use SR correction, just that it's most likely all on the clock/time side
meh... I've scared Tom, Hurkyl, and Doc Al away... wespe you're all i have left!
hold me...
hold me...
We love you too Ram
But, is there an argument left to discuss? (Not case 7. The center of emission is relative so it's not a paradox)
Your last posts indicate you are trying to figure out how GPS works. That's not an argument and there are no questions, so you shouldn't be expecting a reply.
ram1024 said:
so i opened up 3dsMax and started messing with spheres to try and figure out geometrically how GPS would work...
You're operating based on a preconcieved notion of how you think it might work, which is (unsurprisingly) wrong.
When I said you should "choose to learn" these things, maybe I wasn't specific enough. What I meant was that you should choose to learn how these things actually work, not how you think they should work in your nonexistent universe.
Read up on how GPS calculates a position. Read up on how the clocks are synchronized. Read up on what the implications are for Relativity.
Or you could simply admit that you will refuse to learn real science and end this. That is likely the reason why the others have abandoned these discussions.
you're talking as if you're absolutely positively sure that i have no idea what I'm talking about.
do YOU know exactly how GPS works? If NOT then you can't be sure I'm not correct. If SO, it would have been easier to post where i went wrong rather than post a useless paragraph condemning my learning habits.
be part of the solution not part of the problem, MmmKay?
yeh i was waiting for Hurkyl to interpret my spacetime diagram, and Tom to come back with data.
i think they both went on vacation though, i haven't seen them post in other threads either.
As for Doc Al, i think i wore him out :(
the GPS is a good distraction while i wait for their return
Does the fact that you have been arguing your case, and we have been arguing ours as well, for 10 days, and yet no progress has been made? It looks to me like one of us is either refusing to accept a notion, or that ... well actually there's just the one option.
I thought I didn't really have much to say on this thread.
Anyways, http://math.ucr.edu/home/baez/RelWWW/wrong.html is a great page, and it has a section on GPS vs relativity.
wonderfully informative page.
even figured out where i went wrong with my spheres. without knowledge of the sphere's locations relative to each other (satellites) you would need 4 to determine the locations of intersections, but they do a precalculation and send it down as part of the signal. i thought the signal would be simple and the calculations would be done on the receiver end. but they're asserting that the signal carries 9 layers of information and the receivers actually do very little of their own computation. in this sense they only need 3 for triangulation, and the 4th supplies the receiver with the time of the Earth based GPS clock.
good stuff
oh then that was the expected data.. I didn't understand what you meant.
but russ_watters is right IMO, you could learn more efficiently if you did more search and reading, or else you will wear people out
thanks for the link Hurkyl
heh, you guys are under the false impression that i do no reading and investigating on my own :D
i do quite a lot, but as far as stuff online it's quite hard to judge facts from fiction most of the time, which is why before i go into researching i lay out my own "how i think it would work" scenario as a guidestone, and then work the research data into my theory as i progress, using each new piece to compare and contrast to find out how stuff actually works and where i went wrong <if anywhere>
a lot of times i will get conflicting data from sites so generally i tend to go with the ones that DO take the commonly accepted theories "point of view" as being the truth.
if i got bogged down with contradictions i'd never make it anywhere.
and i am truly sorry if i wear you guys out. :(
It would appear (with a gentle nudge from Hurkyl) that you answered your own question. Why couldn't you have just read up on it like I (we) suggested instead of guessing and getting combative when you guessed wrong? Its simpler, faster, and less painful for all of us.
ram1024 said:
...I lay out my own "how i think it would work" scenario as a guidestone, and then work the research data into my theory as i progress, using each new piece to compare and contrast to find out how stuff actually works and where i went wrong <if anywhere>.
And this is why you are having such a hard time learning these things. Its human nature to not want to be wrong and so I understand your frustration. You are trying to learn by a process that ensures that for you to learn something you must first make a guess and be wrong (and accept that you were wrong). On this forum it manifests itself as you making guesses, us trying to help you, and you responding with the natural human instinct of getting defensive/combative. Why put yourself through that? Just learn the right way the first time. Don't guess.
Yes, can be tough to find credible info on the web. We can help. But if you don't trust us, its not hard to figure out on your own what is credible and what isn't.
the process of me guessing helps me to understand the ramifications of why things are the way they are more intuitively.
this is the way that i learn best. <shrug>
take case in point the GPS system. they're doing it with 4 satellites in view, using 3 for triangulation and the 4th to match GPS local time for the Earth based station.
my system would use 4 satellites but we wouldn't need to know the positions of the satellites or local Earth time, as 4 expanding spheres with calibrated time only intersect in 2 places, one would be your position on Earth and the other would be somewhere way off in space.
i don't know if that would make computations any easier or harder, but it is a system that would work, fashioned entirely from my brain in a way that i personally can understand it.
relaying that information in a way that you or anyone else could understand it is indeed a bit more difficult which is why it takes 25 pages for me to get my point across to you guys.
in the end if you guys are simply trying to "teach me" and not also "learn what the heck I'm talking about" then there's a failure on your end as well. because from my standpoint i have taken everything "taught" to me thus far and incorporated it into my "self theory" as retained knowledge. you have simply clung to what you believe and not made an attempt to "learn" what i might have to offer.
Ram, I did learn something from your case#7 (maybe others already knew, but I didn't): that the center of emission is not a space buoy. So, thank you for that. But.. the other cases were a waste of time, due to a lack of knowledge on your side. That's the part that could be eliminated. I didn't say you read nothing, I just said more reading would be better. Sorry if that offended you.
the center of emission HAS to be a space buoy. if it's moving then what's its speed and direction?
the whole "light is not connected to its source" means it either A> has to be stationary absolutely or B> has to move, but relative to what in your guys SR case, in Galilean it would move with the imparted velocity from the source. which is where a lot of confusion comes into play I'm sure. still need the data to verify my postulates.
i will say again, if light is independent of its source then the space buoy HAS to work.
If the center of emission is a space buoy, then speed of light can't be the same for both emitter and receiver.
it's relative to frames and it's not a real object.
so in the moving observer frame, the center of emission is stationary
in the stationary observer frame the center of emission is moving.
that would be consistent right?
but it's not so according to the way you guys are calculating it. you have it stationary in the moving frame and stationary in the stationary frame.
you say it's not a real thing, but it has to be real enough in such that light emitted from that point will spread "at light speed" in all directions. that is a given.
let's analyze that further.
Code:
[u](o)                                                         <-)|[/u]
[u](o)                                                         <-)|[/u]
we're putting two observers next to each other. a flash of light is emitted at the same time from emitters same distance from them. <this can be the same emitter so don't worry about synchronicity>
Code:
[u]            (o)                                                         <-)|[/u]
[u]            (o)                                                         <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                (o)                                                     <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                    (o)                                                 <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                        (o)                                             <-)|[/u]
one of the observers moves towards the emitters. it's guaranteed he gets hit before the other observer due to less distance light has to travel. correct?
now we swap frames
Code:
[u]            (o)                                                         <-)|[/u]
[u]            (o)                                                         <-)|[/u]
Code:
[u]          (o)                                                         <-)|[/u]
[u]              (o)                                                     <-)|[/u]
Code:
[u]        (o)                                                         <-)|[/u]
[u]                (o)                                                 <-)|[/u]
Code:
[u]      (o)                                                         <-)|[/u]
[u]                  (o)                                             <-)|[/u]
or
Code:
[u]            (o)                                                         <-)|[/u]
[u]            (o)                                                         <-)|[/u]
Code:
[u]        (o)                                                         <-)|[/u]
[u]            (o)                                                     <-)|[/u]
Code:
[u]    (o)                                                         <-)|[/u]
[u]            (o)                                                 <-)|[/u]
Code:
[u](o)                                                         <-)|[/u]
[u]            (o)                                             <-)|[/u]
or
Code:
[u]            (o)                                                         <-)|[/u]
[u]            (o)                                                         <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                (o)                                                     <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                    (o)                                                 <-)|[/u]
Code:
[u]            (o)                                                         <-)|[/u]
[u]                        (o)                                             <-)|[/u]
these are the three relative frames i managed to come up with.
the first defining stationary as the point between O1 and O2, having each other move away at same speed. the emitters have to close some of the distance.
the second being O2 stationary, so O1 must move away and the emitters must close the distances
the third being O1 stationary and O2 moving. this is exactly the same case as outlined in the first example.
let's define a length that light travels at a certain time to be light's speed in this scenario.
here is that length
Code:
[u]            (o)                         length                          <-)|[/u]
[u]            (o)                                                         <-)|[/u]
apply that length to the scenarios outlined above as being a constant speed.
you'll see that this length segment coresponds to a space-time such that in the original case allows both observers to be hit by the photon.
in case 2 and 3 the first observer can NOT be hit by his photon during this allotted space-time.
there is only ONE allowable case at constant speed of light that makes it so that length of space time encompasses both observers and that is case 4, which is identical to case 1. so the only answer from an SR standpoint can be that case 2 and 4 are incorrect as reference frames. case 1 is what actually happens.
If your system doesn't take Relativity into consideration, it might work in your universe, but it won't work in ours.
This process certainly does help us to learn (thats part of the reason I'm here), but its learning by finding your errors. You get us to think about these subjects, pick apart your ideas, and find the flaws.
Alright, I'll solve these with my ultimate solvination program: paint.
Just a minute.
time increases upwards
distance between obs and emit = 1m
listspeed = 1m/s for simplicity (if you want I can just make it more than 1 meter, or say it's the meter #2)
I can't believe the imit is 400x400 I had to crunch up my pic and mess everything up!
Anyways this is what would happen.
*edit* it was 402*398 ... fixed now
The "rel.jpg" is just the proff that your buoy won't work
attachments never get approved. better host it somewhere...
OK, here's what I could come up with (someone correct me if I'm mistaken)
Suppose the second emitter was comoving with the second observer.
The emitters emit photons when they meet.
This is o1 frame:
Code:
       (o1)----------------------------------------<-)|
This is o2 frame:
Code:
       (o2)----------------------------------------<-)|
But o1 sees the o2 frame length contracted:
Code:
       (o2)----------------------------------<-)|
Also o2 sees the o1 frame length contracted:
Code:
       (o1)----------------------------------<-)|
According to o1 this is what happened:
observers meet first:
Code:
then emitters meet:
Code:
later o2 detects photon. later o1 detects photon
Code:
According to o2 this is what happened:
emitters meet first:
Code:
then observers meet:
Code:
Code:
So, o2 detects photon before o1 in both frames, but they won't agree on times and distances and simultaneity.
does this make sense?
edit: Your mistake is assuming the photons were emitted at the same time for both observers, which is the time the two observers were at the same location. That would violate relative simultaneity/time. For the moving observer, the photons were emitted some time ago before the observers were at the same location (because of length contraction as I showed above).
Alright! I fixed it.
The green and blue lines are the two different observers.
Blue is the stationary (relative to emitter) observer and green is the moving
The top frame is blue's frame and the bottom is green's
The thick lines are the opposite observer's frame
(you see what they mean by skewed?)
i said already, don't use attachment, they don't get approved. we'll never be able to see them
host it on imagedump or something :|
You're kidding me? You can't see any attachments until they're approved? Even pictures?! (Can you even put damaging stuff in jpeg's? I mean that will be run)
Anyways, I modified the picture a bit, pretty much the same except the thick lines are boxes now.
http://www.vbforums.com/attachment.php?s=&postid=1726678
Red Dot: The buoy
Blue Dot: photon heading towards buoy from emitter
Green Dot: photon heading towards buoy from emitter
http://www.vbforums.com/attachment.php?s=&postid=1726680
I'd also like to point out that this picture is "impossible" because it's drawn as if the buoy were moving relative to it and yet light doesn't move normally (for no speed). It's as if we are observing a frame from a a different frame.
have NO idea what I'm looking at in your first diagram.
in the second one it just seems to prove that it SHOULD work. in order for the lights to simultaneously meet in the center the light from blue travels at 1m/s towards red which travels at 1m/s towards it (1+1=2) and light from green travels at 3m/s but red travels away from it at 1m/s so (3-1=2) light is traveling at 2m/s <lightspeed> relative to the observer <red>
but wait a minute. that means light was really <to no observer> traveling at 3 in one instance and 1 in another instance... what gives?
just to reiterate, the space-buoy does NOT work, but that is not why it does NOT work :D
Do you notice how the light intersects at the buoy (this is a spacetime diagram) and is always equi-distant from it on both sides? That's why ti doesn't work.
The first is also a space time diagram. First ignore the large square (dark blue/dark green) and look. The black line (going straight up in the first, since it is unmoving) is the emitter, red is light (same in both), green is one observer and blue is another.
The dark squares are the other frames. (rotate your head to look at them like that and they look similar to the other diagram, but it is not an accurate representation)
