Torque Application: Simple Q&A Diagram
  • Context: Undergrad
  • Thread starter Thread starter WildEnergy
    Torque
The discussion revolves around understanding torque and the mechanics of a pivot in relation to forces applied to a rigid body. Participants explore the relationship between linear forces, torque, and the role of the pivot, with a focus on conceptual understanding rather than calculation methods. The context includes diagrams illustrating these concepts and the challenges faced in interpreting them.
  • One participant presents a diagram illustrating the application of linear force at the center of mass and offset from it, questioning how torque is generated around the center of mass.
  • Another participant expresses skepticism about the explanations provided in textbooks regarding the pivot, seeking a deeper understanding of the forces involved.
  • There is a discussion about calculating torque from different reference points, with one participant noting discrepancies in torque values depending on whether it is calculated around the center of mass or the pivot.
  • Participants discuss the mechanics of a door opening as an analogy for understanding torque and pivot dynamics.
  • One participant emphasizes a desire to model the pivot as a reaction force rather than relying on conventional calculation methods, indicating a preference for a conceptual approach.
  • There is a debate over the moment of inertia values provided by a physics simulator, with questions about the assumptions made in the simulation regarding the object's dimensions.
  • Clarifications are sought regarding the direction of the applied force as the object rotates and whether external factors like gravity or friction are considered in the scenario.
Participants express differing views on the adequacy of textbook explanations regarding pivots and torque. While some agree on the need for a deeper understanding of the underlying physics, no consensus is reached on the best approach to model the pivot or the accuracy of the moment of inertia values discussed.
Participants note limitations in their understanding of the hidden forces involved in torque calculations and the assumptions made in their simulations. There is also uncertainty regarding the treatment of forces and torques when modeling a pivot in a physics simulator.
  • #31
WildEnergy said:
that confuses me because ... we started with a single external force of 10N and we end up with a resultant linear force of 12.974N and some torque
The object always has the two forces acting on it. When you analyze the rotational motion, you have to choose an axis to calculate the moments about. By choosing the pivot as the location of that axis, the moment due to Fx is 0 regardless of what Fx is. That's exactly why you choose that axis. Doing so eliminates one unknown from the equation and makes it solvable.
  • #32
WildEnergy said:
understood - I was doing a check to match the output of my simulator
can I take it that my workings are correct?
They are correct up to step 4 which you still need to clarify to yourself.
No. We started with a linear force F = 10 N and a horizontal force at the pivot (yet to be determined) such that the pivot remains at rest while the rest of the rectangle rotates about it instantaneously.
  • #33
ok I think I am beginning to see
I was confused before because the unknown force at the pivot was a reaction to the external force
but because the action was exerted on the pivot - and the reaction was exerted on the rod
it becomes part of the total force on the rod
and I was confused about the relationship between translation forces and rotation forces
for instance in this case a torque has resulted in a reaction that has resulted in a change
of both resultant torque and resultant force (change from what would happen without the contact)
but when calculating the acceleration of a non-slipping circle down a slope the force is shared between the rotation and translation so that [tex]a = \alpha r[/tex]
and the contact force must be [tex]2.974N[/tex]
  • #34
Can you finish now? Keep us posted.
  • #35
Thanks for all your help - my understanding is improving :-)
As for finishing - this is just the start - I am writing a vehicle simulator
but both my maths and physics are weak - luckily I do at least know how to write software
I bought a Classical Mechanics book which I am working through now
and this question was related to calculating the lateral friction at the rear wheels based on the steering torque generated by the angled front wheels - that is why I was trying to avoid the pivot concept
I am still keen to find an alternative solution that avoids the parallel axis theorem etc.
  • #36
If there is almost no friction such as when the car is on ice and the car is skidding, then it will turn around its COM as if that is the fulcrum. If there is normal friction between the road and the car and no skidding, then the center of the rear wheels axle, acts as the fulcrum. The back wheels effectively act as the bearings for the fulcrum or hinge and there is no lateral friction on the rear wheels due to the turning torque of the front wheels. The way to calculate the lateral friction of the rear wheels is to work out the "centrifugal force" of the turning car and the lateral friction of the rear wheels will be equal to the centripetal force required to keep the car moving in a circle and the pivot concept is irrelevant.
  • #37
Brilliant - that way of looking at it really helps :-) Thanks
  • #38
I found a very easy and intuitive way to solve this by considering the constant relation:
Atotal = Aforce + Atorque
Aforce = F / m
Atorque = F * d * d / I
now it is easy to work out the force at the contact point
  • · Replies 60 ·
  • · Replies 23 ·
  • · Replies 53 ·
9K
  • · Replies 21 ·
  • · Replies 35 ·
  • · Replies 31 ·
