Torque calculation for a compound pendulum
15 replies · 3K views · last reply
charon_9
Newton's second law on a compound pendulum
I*α = ΣM, F=-kx, G=mg
Diagram of a rigid rod pinned at the top to a ceiling and swung to an angle theta from the vertical dashed line, its lower end attached to a horizontal spring between two walls.
I need to write an equation for Newton's second law for the above system, where k1=k2 (both springs are the same). The red line represents a bar with m=2kg, l=2m.
I know that I*α = M1 + M2 + M3
If we displace the bar by x, we get the angle of displacement theta.
M1=M2=-k*x
I know that, judging by the picture, tan(Θ)=x/l, thus x=tan(Θ)*l.
However, my workbook states that M1=-k*tan(Θ)*l*l*cos(Θ). Where did the l*cos(Θ) come from?
Setting the workbook aside for the moment, how would you write Newton's second law for this arrangement?
Strictly speaking, the springs will not remain horizontal. As the rod swings, its end will rise slightly. So is ##x=l\tan(\theta), l\sin(\theta), ## or ##2l\sin(\theta/2)##?
I'm sure we will be doing a small angle approximation, so it is not going to matter. I.e. ##\cos(\theta)\approx 1##.
Yes, we're always using an approximation that $$cos(\theta) = 1$$ for small angles.
Thing is, I can understand that $$M_1 = kx \cdot r$$, where I already figured out that $$x=l\tan{\theta}$$
However, I really can't figure out where they got the $$l\cos{\theta}$$ in
$$M_1=-kl\tan{\theta} \cdot l\cos{\theta}$$
Well,
$$I\alpha = M_1 + M_2 + M_3$$ where $$M_1 = M_2$$.
$$M_1 = M_2 = -k \cdot l\tan{\theta}$$
Now I get stuck figuring out the radius part. I have no clue where they got the cosine from.
For the figure shown below, how would you express the moment (torque) about O of the force F in terms of F, l, and ##\theta##?
Diagram of a rod hanging from pivot O at its upper end, tilted by angle theta from the vertical, with length l labelled along it and a horizontal force F acting to the left at its lower end.
(They appear to be ignoring the tilt of the springs pointed out by @haruspex .)
To add to what @TSny posted, the picture that you posted in #1 is misleading. Strictly speaking, as the rod swings to some angle, the springs will no longer be horizontal. However, in the small angle approximation, you have ##l\cos\!\theta \approx l## and it wouldn't matter that the springs are not horizontal.
Thank you for taking the time to answer.
Wasn't it $$M=r \times F = r \cdot F \sin{\theta}$$
##|\vec r \times \vec F| = rF \sin\phi##, where ##\phi## is the angle between ##\vec r## and ##\vec F##. Is the angle ##\theta## is the diagram the same as the angle between ##\vec r## and ##\vec F##?
Sorry for posting a misleading picture, that's what I have been provided with by my school. I'm once again sorry.
I did some testing so please tell me if I'm right or wrong.
Because the springs are a bit elevated. their force F has a vertical component and a component in the direction of $$\theta$$. We need the component in the direction of theta, so $$G_t = G\cos{\theta}$$.
As for the ##l##, it is the radius, or the distance from the tip of the bar to the point about which it oscillates. Is this correct?
No, that's ok, we know it is not your picture. I think @kuruman was just making sure you were not being misled by it.
G? Gt? What has that to do with the tension in the springs?
The elevation of the springs will not be to angle ##\theta##. It will depend on the spring length, so taking them to be extremely long gets rid of that problem.
charon_9 said:
As for the l, it is the radius, or the distance from the tip of the bar to the point about which it oscillates. Is this correct?
Yes.
Yes.
haruspex said:
No, that's ok, we know it is not your picture. I think @kuruman was just making sure you were not being misled by it.G? Gt? What has that to do with the tension in the springs?
Yes.
Sorry. I was quick to reply so I mistook ##G## for ##F##, the elastic force.
This is my guess. Let's say the springs tilt up for a small angle. This means that the elastic force has a vertical component to it (in the negative direction of the y axis in an XY plane). We need the other component - the one that "pulls" to the left.
Handwritten free-body diagram of a hanging pendulum with angle θ from vertical, showing forces F_T, F_N and F, and the equation cos θ = F_T / F.
I didn't draw the springs in order to not make the sketch a mess. I just named the components as such, where ##t## would be tangential and ##n## would be perpendicular.
As I posted, the angle the springs make to the horizontal will not be the same angle the rod makes to the vertical. To see that, try including the springs in the diagram, making them much longer than the rod.
Because we don’t know the lengths of the springs, we cannot know the angle they make.
Okay, thanks. I have one more question, though. I decided not to open a new thread, but please tell me if I need to.
I took this photo from a very old textbook, where it asked us to write the same equation for this system, where the mass of the disc is ##M=2##, and ##k=37.5## for both springs. The solution says that
$$I\alpha = kx \cdot 2R$$
$$x = 2R \cdot \tan{\theta}$$
$$I \alpha = -4kR^2\tan{\theta}$$
I now have two questions:
1. Why did they only include the torque for one spring? Shouldn't it be ##2 \cdot -4kR^2\tan{\theta}##, like in the first example?
2. Why isn't the torque for the gravitational force included, also like in the first example?
Diagram of a disc resting on a horizontal surface at point O, with a horizontal spring attached to its top on each side, each spring anchored to a wall, and small arrows at the top of the disc indicating horizontal motion.
No idea. Both look like mistakes to me. Leaving out gravity would have made sense if the disc were rolling back and forth on a flat surface, but it is clearly mounted on a pivot.
