Torque calculation on drive half shaft in coast downshift condition
3 replies · 3K views
kkd
I want to calculate the torque coming onto a half shaft in a very particular event.
The event is I let's say I am in 3rd gear and have reached my max torque zone after which I have taken my foot of the acc pedal...nw I m letting the the vehicle coast as soon as it reaches say 60% of max power rpm I downshift to 2st gear and after downshift m still not pressing the acc pedal..m just letting the vehicle drive by its momentum..
Now during my downshift as soon as I engage the clutch I will have a very high amount of torque cmng onto the shaft...
Pls guide me how to proceed to calculate this torque..!
Thanx in advance... :)
As always, draw a free body diagram.
The braking torque depends on the motor characteristics.
You need to calculate how much torque is required to run the engine against a closed throttle... No easy task...
Do you know the fluid friction across the butterfly etc?
Thanx billy for your reply...
It is basically a fuel in injected engine...I had some some data regarding the drag torque of the engine... If I multiply that value to the gear ratios the torque which is coming is to the tune of 200 Nm per shaft..the wheel slip torque if I consider .8 coefficient of friction comes up to 830 Nm but the incident which I mentioned above the values of torque varies from 1300 Nm to 1700 Nm depending upon the way clutch is released...1300 for gradual & 1700 for sudden...
Also include the force needed to accelerate the flywheel and rotating/reciprocating mass of the engine.
