Torque on two pillars (introductory physics problem)
  • Thread starter Thread starter Camden
    Physics Torque
The discussion revolves around a physics problem involving torque and forces acting on two pillars supporting a structure, likely a bridge, with a car positioned above them. Participants are exploring the distribution of forces and moments due to the car's weight and how to analyze the system's equilibrium.
  • Participants discuss the distribution of weight on the pillars, questioning whether the weight is equally shared or concentrated on the pillar directly beneath the car. There are inquiries about the definition and application of torque and moment balance, as well as the need for formulas related to equilibrium.
The discussion is active, with participants raising questions about assumptions and clarifying concepts related to torque and equilibrium. Some guidance has been offered regarding the application of moment balance and the importance of defining the system being analyzed.
Participants express uncertainty about specific terms and concepts, such as "moment balance" and the conditions for equilibrium. There are references to external resources for further clarification, indicating a collaborative effort to understand the problem better.
Camden
A bridge section of mass 2400kg is supported at each end of its 24.0m length by pillars. A car of mass 960kg is parked 5.00m from one end of the bridge.
F=ma
T=Fsin(theta)r
One image is attached is the question and the other is my attempt. I believe the pillars would have a downward force of 11760N applied to each pillar since they are spaced an equal distance apart. Now the tricky bit is when Torque comes into play. I believe I need to find the distance the car sits from the centre of the bridges mass. I am unsure how to do that though.
My neck hurts, perhaps because the pictures are rotated ?
Your belief is not justified. If the car is on top of one of the pillars, would its weight be distributed equally over the two ?
from what?
haruspex said:
from what?
From each other
I believe the pillar the car is almost directly underneath will experience more weight from the car.
Camden said:
From each other
How can two objects not be at the same distance from each other??
Much better. Any useful formula for the fraction (perhaps derived from an applicable condition for equilibrium of the horizontal section that rests on the pillars) ?
The car is above the pillars, not underneath them.
But yes, the pillar nearer the car will experience the greater load.
Use moment balance to find out how much.
Are there any other phrases that mean the same as Moment balance? I have not been taught that particular word before.
So I believe the net Torque should be zero. I am unsure which formula I should be deriving from.
Moment is another word for torque, and balance means the net value is zero.
You quoted T=Fsin(theta)r. Do you understand what F, r and θ are in that equation?
Yes I do,
F= Force applied
r= Distance force is being applied from
theta= angle at which the force is being applied
So is my first step 0= Fsin(theta)r ?
Camden said:
Yes I do,
F= Force applied
Yes, but you need to choose the body you are applying it to and the axis about which you are taking moments.
And to clarify, theta is the angle between the line of action of the force and the line along which you are measuring r.
  • · Replies 45 ·
