How Does Torque Affect Body Stability in Ergonomics?
  • Thread starter Thread starter pennywise1234
    Torque
Torque plays a critical role in body stability and ergonomics by acting as a turning moment that influences rotational motion. The mathematical definition of torque is given by the equation $$ \tau_{Total} = \sum_{i} \tau_{i} = \sum_{i} \vec{r_{i}} \times \vec{F_{i}} $$, where torque is the product of the position vector and the force applied. For equilibrium, the total torque on a body must be zero, indicating that angular momentum remains constant. Understanding the relationship between torque, center of mass, and base of support is essential for improving stability in ergonomic design.
  • Understanding of basic physics concepts, particularly torque and angular momentum
  • Familiarity with mathematical equations related to rotational motion
  • Knowledge of human anatomy, specifically joint mechanics
  • Basic principles of ergonomics and stability
  • Research the relationship between torque and center of mass in human biomechanics
  • Explore ergonomic design principles that enhance stability through torque management
  • Learn about the application of torque in physical therapy and rehabilitation
  • Investigate tools for measuring torque in ergonomic assessments
This discussion is beneficial for ergonomists, physical therapists, biomechanics researchers, and anyone involved in designing stable ergonomic systems or improving human movement efficiency.
pennywise1234
1. The problem statement
what role does torque play in body stability and ergonomics ?
I'm not sure what level of explanation you want... Most simply, torque is a turning moment. The idea of torque is that if you apply a force at a greater distance, you get a bigger rotation - it would be easier to swing a cat by its tail than its middle (if you wished to swing cats), and it requires less effort to open a door from the edge, rather than at the pivot.
If you want a mathematical definition:
Where ##\tau_{Total}## is the total torque on the body, and is the sum of a number of torques, ##\tau_{i} = \vec{r_{i}} \times \vec{F_{i}}## where, ##\vec{r_{i}}## is the position vector, and ##\vec{F_{i}}## is the force.
The angular momentum of a body is related to the torque applied:
$$ \vec{L} = \vec{r} \times \vec{p} $$
$$ \frac{d\vec{L}}{dt} = \frac{d\vec{r}}{dt} \times \vec{p} + \vec{r} \times \frac{d\vec{p}}{dt} $$
So
$$ \frac{d\vec{L}}{dt} = \vec{r} \times \vec{F} $$
i.e -if we don't have any torque, then the angular momentum must be constant in time. The body cannot be spinning up or spinning down - in cannot be changing its motion in any rotational sense. So in this way, we see that a necessary (but not sufficient! - e.g we also have to balance forces) condition for equilibrium is that the total torques on a body must be zero...
Does that help at all?
Penny... have a think about the joints in the human body. I think all (?) Involve rotation.
The question is more geared towards when trying to improve stability or how do stability and torque correlate. I was thinking it had to do with Centre of mass or base of support. I have no idea what could be said for ergonomics
