Total pressure and Static Pressure and V
The discussion centers on the confusion surrounding total pressure (Pt) and static pressure (Ps) measurements in a wind tunnel experiment involving an aerofoil. The participant reports Pt as 11.4mm and Ps as 16.8mm, leading to a negative dynamic pressure, which is incorrect since total pressure must always be greater than or equal to static pressure. The issue arises from potential misinterpretation of pressure ports and the use of a pitot-static tube, which combines total and static pressure measurements. Correct calculation of the pressure difference is essential for determining freestream velocity accurately.
  • Understanding of fluid dynamics principles, specifically Bernoulli's equation.
  • Familiarity with pressure measurement tools, including pitot tubes and manometers.
  • Knowledge of pressure types: total pressure (Pt) and static pressure (Ps).
  • Basic concepts of airflow around aerofoils and their pressure distributions.
  • Study the operation and application of pitot-static tubes in fluid dynamics.
  • Learn how to calculate freestream velocity using pressure measurements with Bernoulli's equation.
  • Explore the effects of different fluid densities on pressure readings in manometers.
  • Investigate common errors in pressure measurement setups and how to avoid them.
Aerospace engineers, fluid dynamics researchers, and students studying aerodynamics who seek to understand pressure measurement techniques and their implications in wind tunnel testing.
Ma77h3w
Confusion... I'm probably being stupid but...
Aerofoil in a wind tunnel... there are lots of pressure tappings including Pt and Ps (static and total pressure freestream) these are currently in mm on a manometer..
my Pt is 11.4mm and Ps is 16.8mm.. (SG=0.8)
1st question: Should total pressure be less than static? because i can't solve the equation to find free stream velocity.. rearranging: Pt - Ps = 1/2 p V^2 (p = density)
as Pt - Ps is negative.. hence finding V is impossible.. can't root a negative. Have i mixed the two up?
however my Cp against x/c graph looks good.. and swapping Pt and Ps messes it up..
Thanks
I'm not sure, I don't have access to the experiment anymore. What difference would using a pito static tube make?
Can the Dynamic pressure (Pt - Ps) be negative in this situation? And am I allowed to swap them around (Ps - Pt) to work out the freestream velocity?
All the other pressure tappings on the aerofoil itself at 0 incidence are between 15 and 19mm. It's only the so called Pt that's as low as 11.4mm.. Thought: maybe I'm being silly and the lower the (mm manometer fluid) the greater the pressure...? Confusion reigns
for information manometer (table?) is at 20 degrees and fluid = 800 kg/m3
The static and total ports are linked together to do the subtraction for you, providing one number for your data: the velocity pressure.
Not unless the flow direction was backwards.
Without knowing what the port that is labeled "Pt" really is, it is tough to help. But total pressure can't be less than static pressure...
...or are these other ports that are labeled as static pressure acutally pressure ports along the profile of the airfoil? In that case, they aren't freestream static pressure.
Total P is always greater than or equal to static pressure
I guess u r wrongly calculating the pressure difference... let me guess..
u would have connected the pitot tube(measures tot P) to a manometer (A) at the top
Static tube(measures Static P) to another manometer (B) at the top...
Condition: both manometers exposed on the other tube to same atmospheric conditions
Now u have less pressure acting on the water column at B.. so the water level will be higher, say h2; on the other hand u ve more pressure acting on the water column at A.. so its level will be lower, say h1..
This implies, higher P keeps the water column lower... so u would have calculated the pressure diff as rho*g*(h2-h1) which is actually (Tot P-Static P)... Now u cud get the vel right
Can you not use text speak please.
okay...hereafter i will be conscious about that.. thank you
  • · Replies 19 ·
