- 37,494
- 14,383
That would violate quantum mechanics, energy conservation, and probably some more laws, at the same time. Each measurement localizes the particle, you can't have the particle jumping around like crazy between measurements.TrickyDicky said:Generating a multitude of different trajectories(one for each interaction) would be the expected outcome for a spherical wave function, and it would be an equally consistent result, but it is not what is observed.
In many worlds, you get many trajectories at the same time, but in different branches of the world, so you always see just one trajectory.
There is no fixed size limit. Just a decoherence limit that depends on the experiment.We know quantum effects are negligible for macroscopic objects(sand grains, pick-up trucks,... but not for say buckyballs).
By the way, quantum effects are not negligible in macroscopic objects - without quantum mechanics, chemistry would not work.
Not significantly in the sense of decoherence within the relevant timescale, otherwise we would not see quantum effects at all.Again, I think all quantum systems interact significatively with the environment.
Decoherence/Measurements on a timescale of picoseconds.stevendaryl said:Well, sort of. If the atoms themselves have a definite location, then interacting with the atoms would localize the particle. But why should the atoms themselves have definite locations?
Sure, because they interact with the atoms, and some interactions change the momentum significantly.atyy said:Also, as one can see in the beta particles do not have straight line tracks in the cloud chamber.
Let's say decoherence is needed. There are interpretations of QM that do not need collapses.Whatever way one does it, a collapse is needed.
The uncertainty is negligible compared to the size of the bubbles.StrangeCoin said:I'm not sure what is it exactly you are suggesting, but we can bend those trajectories with magnetic fields and they go right where they are supposed to go, according to classical prediction.
So how is that possible if the electron was not exactly on the continuous path between every two successive bubbles? If it was going anywhere else its acceleration wouldn't be uniform, it's velocity would vary which in turn would cause magnetic force to vary and it would not pass through all the expected bubble "check-points" as it does.
