Tracks in particle detectors and quantum paths
127 replies · 18K views
TrickyDicky said:
Generating a multitude of different trajectories(one for each interaction) would be the expected outcome for a spherical wave function, and it would be an equally consistent result, but it is not what is observed.
That would violate quantum mechanics, energy conservation, and probably some more laws, at the same time. Each measurement localizes the particle, you can't have the particle jumping around like crazy between measurements.
In many worlds, you get many trajectories at the same time, but in different branches of the world, so you always see just one trajectory.
We know quantum effects are negligible for macroscopic objects(sand grains, pick-up trucks,... but not for say buckyballs).
There is no fixed size limit. Just a decoherence limit that depends on the experiment.
By the way, quantum effects are not negligible in macroscopic objects - without quantum mechanics, chemistry would not work.
Again, I think all quantum systems interact significatively with the environment.
Not significantly in the sense of decoherence within the relevant timescale, otherwise we would not see quantum effects at all.
stevendaryl said:
Well, sort of. If the atoms themselves have a definite location, then interacting with the atoms would localize the particle. But why should the atoms themselves have definite locations?
Decoherence/Measurements on a timescale of picoseconds.
atyy said:
Also, as one can see in the beta particles do not have straight line tracks in the cloud chamber.
Sure, because they interact with the atoms, and some interactions change the momentum significantly.
Whatever way one does it, a collapse is needed.
Let's say decoherence is needed. There are interpretations of QM that do not need collapses.
StrangeCoin said:
I'm not sure what is it exactly you are suggesting, but we can bend those trajectories with magnetic fields and they go right where they are supposed to go, according to classical prediction.
So how is that possible if the electron was not exactly on the continuous path between every two successive bubbles? If it was going anywhere else its acceleration wouldn't be uniform, it's velocity would vary which in turn would cause magnetic force to vary and it would not pass through all the expected bubble "check-points" as it does.
The uncertainty is negligible compared to the size of the bubbles.
Yes. My point is that we are just doing quantum mechanics here, so we are not trying to get rid of collapse. Asking for a solution to the measurement problem is beyond the scope of this question.
It's very important to "get rid of the collapse" by just not introducing it. It only causes a lot of trouble, including the whole EPR debate etc. The good thing is that it's not needed at all. Instead we can simply take Born's postulate serious and take the Minimal Statistical Interpretation. That's how, in fact, quantum theory is used in practice, when real-world experiments are made in the labs and described with help of quantum theory.
TrickyDicky said:
No angular dependance(angular invariance) is equivalent to spherical symmetry so in what sense it is only apparent?
You cannot observe the spherical symmetry in a single run of the emission experiment. In a simplified situation where the alpha particle is emitted into a perfect vacuum and detected by a 4π array of position detectors, only one of the position detectors will click. In order to conclude that the emission process is spherically symmetric you have to repeat the experiment many times and note that all position detectors click equally often. Analogously, the spherical symmetry of the problem at hand manifests in the fact that all linear tracks are equally likely.
mfb said:
[about why baseballs seem to have definite positions] Decoherence/Measurements on a timescale of picoseconds.
That's probably true, but it seems like overkill to explain a baseball.
If you prepare a baseball at a position [itex]x[/itex] with position uncertainty of [itex]\Delta x[/itex], then the expected length of time required for it to be at a location significantly different from that (just taking into account QM) is on the order of [itex]\dfrac{m \Delta x^2}{\hbar}[/itex]. For baseball-sized values of [itex]m[/itex] and [itex]\Delta x[/itex], that can be a huge length of time. So once prepared in a more-or-less definite position, a baseball will keep to an approximately classical path for a long time without the need to invoke decoherence.
TrickyDicky said:
but it is totally irrelevant and unrelated to what is being discussed in this thread.
Do you know the answer or don't you? If you don't, perhaps it is unwise to be telling people that what they are posting is irrelevant.
TrickyDicky said:
We are instead dealing with a microscopic quantum system that shows classical trajectories in some instances but not in others, it is kind of the opposite case.
This is why I made a big deal of pointing out where you were going wrong. You are still holding on to that wrong viewpoint, which is why you will never understand it.
How so?, be specific.
When I mention multiple trajectories I obviously don't mean simultaneously, but sequentially as it interacts with the chamber environment.
I'm not sure what you are calling measurements in this context, if every interaction with the environment was a measurement in the sense of collapse then we would not see quantum effects at all, it would all be classical. Or as you say:
If all interaction with the environment is a measurment with decoherence we would indeed not see them.
You sure made a big deal,(it would be nice if you toned down your emotional reactions if only to comply with the civility values posted by Greg in PF's main page), what you haven't even hinted at is what you consider my wrong viewpoint so I can correct it if necessary. Have you even considered that you might be misunderstanding my viewpoint?
TrickyDicky said:
If all interaction with the environment is a measurment with decoherence we would indeed not see them [quantum effects].
There is a meta-question about your questions: Are you asking for detailed calculations that show why an alpha particle in a bubble chamber has an apparently definite trajectory, while an electron in a hydrogen atom apparently doesn't? Without doing the calculations, I feel that the two cases are different enough that you shouldn't expect them to be similar. The detailed calculations have been done showing how the tracks in a bubble chamber are consistent with quantum mechanics. In the case of a hydrogen atom, the effects of the environment would certainly be tiny compared with the effects of the coulomb attraction. So I certainly wouldn't expect the environment to be important.
In this paper:
http://arxiv.org/ftp/quant-ph/papers/0306/0306072.pdf
there is a formula giving an order-of-magnitude estimate of the decoherence time. The authors claim:
For microscopic systems and, occasionally, even for very macroscopic ones, the deco-
herence times are relatively long. For an electron...[the decoherence times] can be much
larger than the other relevant time scales on atomic and larger energy and distance scales.
In this paper:
Yes, that is part of what I'm after with my questions. Maybe not so much a detailed comparative calculation between the two cases(which I think it's much to ask in a forum, besides my math wouldn't be up to par to seriously analyze them), but more of conceptual explanation of the key differences wrt definite trajectories between those cases.
I know the effects of the environment are tiny compared to the coulomb atraction, but I'm having difficulties seeing how that is different from the case of a particle in a chamber with say a very powerful magnetic field deflecting the trajectory of the charged particle but not making it any less definite.
I'll take a look at the reference, thanks Daryl.
In practice, there is not much difference between all the various interpretations of quantum mechanics. The Von Neuman recipe that measurement collapses the wave function works perfectly well. The various debates are really trying to understand what the quantum recipe means.
You say that in practice, you don't need anything like collapse, but I don't see that that's completely true. What you do in performing an experiment is to prepare a system in a particular state, let it evolve, the perform a measurement. But how do you prepare a system in a particular state, in the first place? Well, one approach is to use measurement: If you want to prepare electrons in the spin-up state, you start with a source of electrons, and measure the spins (via Stern-Gerlach, or whatever). Then you only use those that have spin-up. But why does measuring spin-up mean that the electron is in the spin-up state after the measurement? Isn't that a collapse-type assumption?
I know the effects of the environment are tiny compared to the coulomb atraction, but I'm having difficulties seeing how that is different from the case of a particle in a chamber with say a very powerful magnetic deflecting the trajectory of the charged particle but not making it any less definite.
I'm curious: how did you know that my name was "Daryl", when my user name is stevendaryl? (Daryl is actually my middle name, and Steven is my first name, but I go by Daryl)
Didn't even notice it, I just used it for short, elsewhere I think I used Steven,:smile:
For the question of why decoherence doesn't decohere everything, the conceptual answer is that there are different strengths of interactions. From the measurement point of view, this corresponds to measuring position with different degrees of precision. For specific examples of how even in the presence of decoherence leading to non-unitary dynamics, there can be subsystems which are decoherence free and continue to evolve unitarily, one review is http://arxiv.org/abs/quant-ph/0301032 .
There's an analogous problem in the quantum Zeno effect, in which continuous accurate measurement freezes a system. However, once again, the measurement does not have to be accurate, and the system does not have to freeze completely. There can even be unitary dynamics in a subsystem. http://arxiv.org/abs/0711.4280
One of the authors on the linked papers above, Pascazio, has addressed decoherence and particle tracks in a cloud chamber. http://www.ba.infn.it/~pascazio/publications/Particle_tracks_and_the_mechanis.pdf
Thanks, atyy, I'll take a look at those references.
Ok, I can see how not having classical orbits for electrons in atoms doesn't have any bearing on having classical trajectories for electrons in cloud/bubble chambers or the Mott problem. There is a key difference in the size vs momentum imparted by environment between the tiny atom and the chamber. The "resolution" needed is much bigger for the atom and the act of measurement completely discards even the idea of a trajectory.
Thinking it over I would say that it is deceiving to think in terms of trajectories even in the case of the tracks in particle detectors. One just observes the result of interactions and constructs something like a classical trajectory.
So if one thinks about the wave function of the whole environment+original source of interactions be it alpha decay or any other process interacting with the environment, the spherical symmetry is still there and there is no paradox at all. It is only when one clings to a discontinuous view of the wave function that one gets in trouble with spherical waves vs. "linear" tracks.
Comments, criticisms?
Nugatory said:
Wave descriptions (not necessarily spherical) of individual microscopic particles may be where quantum mechanics started, but it long ago grew beyond that early formulation of the problem. Quantum mechanically two entangled particles in the singlet state are not two microscopic particles; they're a single quantum system with a single wavefunction and two sets of observables on that system. Including the environment increases the complexity of the system (enough that completely different computational methods may be needed) but even before we include it, we've lost any sense of individual microscopic particles.
(my bold)
I guess I should have payed more attention to this.
Bravo, I feel we are getting there! I am totally happy with the first paragraph, not so sure about the second paragraph though. What is this spherical symmetry idea? All backwards moving waves are self-cancelling (although actually it was not Huygens who proved this, it came later).
I think the idea of whether the trajectory is continuous or not is very technical, and not very conceptual. Conceptually, one can always assume a discretization that is much finer than the spatial resolution of one's measurements, and "construct" the continuous track from these low resolution readouts. It's in the same spirit as lattice simulations of quantum field theory, which cannot have true Lorentz invariance, but can be Lorentz invariant for all practical purposes, as long as the discretization is much finer than what current experiments can see. Mathematically, it does matter, and one can worry about whether the continuum limit really exists, but I would say that at the physics "conceptual" level, there is no big distinction between continuous and discrete (there are exceptions to the rule of thumb, eg. chiral interactions on a lattice, but let's worry about that elsewhere).
In the 2 methods of analysis the conceptual puzzles are different.
1) In decoherence followed by a single measurement and collapse, the puzzle is indeed why decoherence localizes objects. The general answer is that interactions are local in space, with nearby objects interacting more strongly, and distant objects interacting more weakly. This is just a fact of nature that we incorporate into our models of decoherence. Incorporating this fact leads to localization by decoherence.
2) In the case of multiple successive measurements, it's no puzzle why localization occurs, since each position measurement will collapse the wave function into something like a definite position. The puzzle is why in many cases the track is straight enough to get a pretty accurate momentum measurement, which seems to violate the restriction on simultaneous accurate measurement of position and momentum. The answer is that in many cases, the position measurement is inaccurate. An inaccurate position measurement gives a definite position readout, but it does not localize the wave function very tightly. Once localization occurs, then given a spherical wave function, the spherical symmetry is broken on any single measurement trial, but preserved over multiple measurement trials.
Oh, the spherical symmetry(isotropy) idea is specific to those systems with such symmetry like it is the case for high energy physics experiments in particle colliders and bubble/cloud chambers. Not meant as something general.
It didn't occurr to me to think of the linear tracks as related to the Huygens principle but it is a nice way to get an understanding of the Mott problem, relating it to the path integral approach, for instance this quote from wikipedia seems pertinent if one trades isotropic space/medium and real waves for isotropic system wavefunction that includes the environment:
"Huygens' principle can be seen as a consequence of the isotropy of space—all directions in space are equal. Any disturbance created in a sufficiently small region of isotropic space (or in an isotropic medium) propagates from that region in all radial directions. The waves created by this disturbance, in turn, create disturbances in other regions, and so on. The superposition of all the waves results in the observed pattern of wave propagation.
Isotropy of space is fundamental to quantum electrodynamics (QED) where the wave function of any object propagates along all available unobstructed paths. When integrated along all possible paths, with a phase factor proportional to the path length, the interference of the wave-functions correctly predicts observable phenomena. Every point on wave front acts as the source of secondary wavelets that spread out in the forward direction with the same speed as the wave. The new wave front is found by constructing the surface tangent to the secondary wavelets."
2) In the case of multiple successive measurements, it's no puzzle why localization occurs, since the position measurement will collapse the wave function into something like a definite position. The puzzle is why in many cases the track is straight enough to get a pretty accurate momentum measurement, which seems to violate the restriction on simultaneous accurate measurement of position and momentum. The answer is that in many cases, the position measurement is inaccurate. An inaccurate position measurement gives a definite position readout, but it does not localize the wave function very tightly.
According to the Copenhagen interpretation both methods are equivalent, or so It claims the first refence given by stevendaryl when analyzing the early works of Heisenberg and Born.
I myself see too many holes in 2) to agree they are equivalent, in any case I prefer 1), and I don't quite agree with you that there is no big distinction in this respect between a discrete and a continuous model, in fact a continuous field model easily solves the puzzle you mention for decoherence and localization for 1)
I see some analogies here to the quantum Zeeman effect, with continuous measurement surpressing the random outcomes...
You lost me here, what is the analogy?
TrickyDicky said:
How are the track leftt say by an electron in a cloud chamber and its wave function undefined trajectory related exactly?
I have not read all posts in the thread, so I'm not sure if someone gave a satisfying answer.
The uncertainty of postion-momnetum of particles is of order of the Planck constant, but the momentum of high-energy particles is of course much higher than that. So you have more "leeway" for those particles.
The same as when you squeeze a particle in tiny box, it gains higher and higher momentum in the box which in turn allows it to have higher momentum spreads according to HUP.
Thanks, I basically got around to it in #76.
What holes do you see in 2?
(I agree with the Born and Heisenberg views in the reference given by stevendaryl that both methods should be equiavlent in Copenhagen. There are some problems, since placing the Heisenberg cut requires common sense, but I don't believe the problems occur in this case. For an example of problems with wrong placement of the Heisenberg cut, see http://arxiv.org/abs/quant-ph/9712044)
Jilang probably meant quantum Zeno effect.
I generally dislike the Copenhagen interpretation, especially the artificial separation between quantum systems and classical apparatus to observe them. In this particular case of the Mott problem I find more elegant the decoherence view.
Ah,ok then. I think I even mentioned the effect at the start of the thread.
Yes, one can take MWI and decoherence. I'm not sure MWI totally works, but let's assume it does. In that case, 2) can be rephrased as mutiple decohering events, one for each of the successive measurements. So 2) should also have an analogue in MWI.
No, this was about the atoms in the bubble chamber.
All collapse-free interpretations give you a way to prepare a pure, well-known state. Even the procedure to do this in the lab is the same, just the interpretation how it happens differs.
Sorry, how can I be more specific than "particles teleporting randomly around in a bubble chamber of arbitrary size (even with superluminal speeds if it is large enough) are unphysical"? This is contrary to all physics we know of.
I never said "every interaction". Many interactions of a fast charged particle with an atom in a liquid medium count as measurement.
Right.
If you use the many-worlds interpretation, for example, the wave function of the whole system keeps the spherical symmetry of the initial particle. But the system quickly decomposes to many different branches that will never "see" (influence) each other again afterwards. Each branch just sees one (nearly) classical trajectory.
I don't have a single favourite interpretation but I dislike MWI even more than Copenhagen. :rolleyes:
