Transfer of Momentum: Ball Speed Change?
  • Thread starter Thread starter nilic1
    Momentum
The discussion centers on the speed of a ball after it is thrown horizontally and the principles of momentum conservation and Newton's First Law. Participants debate whether the ball's speed increases, decreases, or remains constant post-release. The consensus is that the ball retains its speed immediately after release, as it becomes independent of the hand, with only external forces like weight and drag acting on it thereafter. Momentum transfer occurs only when forces act between objects, which is not the case once the ball leaves the hand.
  • Understanding of Newton's First Law of Motion
  • Familiarity with the Law of Conservation of Momentum
  • Basic knowledge of forces acting on objects (e.g., weight, drag)
  • Ability to analyze Free Body Diagrams (FBD)
  • Study the implications of Newton's First Law in different scenarios
  • Explore momentum transfer in elastic and inelastic collisions
  • Learn how to draw and interpret Free Body Diagrams (FBD)
  • Investigate the effects of air resistance on projectile motion
Physics students, educators, and anyone interested in understanding the principles of motion and momentum in classical mechanics.
nilic1
Does the speed of a ball increase, decrease or remain the same once it leaves the hand as it being thrown horizontally?
Law of conservation of momentum[/B]
According to my calculations, it increases as momentum is transferred from the arm/hand to the ball. I feel it is right though according to a friend of mine it is wrong as the speed should be unaltered according to Newton's 1st law. Who of us is right?
(Bold underline emphasis is mine)
Once the ball has left the hand, what influence can the hand possibly have on the ball afterwards? What forces, if any act on the ball once it has left the hand? Draw a FBD.
None. Except weight and drag. So who is right? :)
Does the force of its weight cause it to accelerate?
As it stands, based upon the logic used to deduce each answer, neither of you is right :smile:
Pardon me but how can it be that none of us is right. The speed of an object immediately after being thrown can either increase, decrease or remain the same. I don't see any other option. We are assuming no external forces are acting and using the law of conservation of momentum.
One of you can have the correct answer but for the wrong reasons (incorrect logic/working). You'd get few or no marks on a test or submitted homework for an answer based upon faulty logic.
I don't know whether you are understanding me. On the same principle, imagine 2 objects moving together as in the case of a person on a horse moving at 10 m/s. If the horse suddenly stops with zero velocity, the person will keep moving forward with a greater speed compared with the speed he was moving previously. Unless this is right my teachers are teaching me wrong stuff.
In my opinion Newton's 1st applies in conjunction with the principle of conservation of momentum.
When according to Newton's first law we say that the object continues to travel at constant speed, it does not mean the speed which both hand and ball have before they get detached from each other. The constant speed starts from the moment that the two bodies become detached. Am I right?
Please reassure me about this!
If you can neglect air drag, then, for the system you described, the horizontal component of velocity remains constant. What do you think happens to the vertical component of velocity? What is the speed of the ball expressed algebraically in terms of its horizontal and vertical velocity components?
You are either misunderstanding what your teacher is saying or your teacher is saying something incorrect.
The person would continue moving at 10 m/s if the horse suddenly stopped (presuming that the person and horse are not attached in some way). Momentum transfer, as in a collision, requires that forces act between the objects. If the man is simply perched on the horse and he can slide without friction off of it, then no momentum transfer will take place.
The hand and ball become entirely independent once contact is broken. They share the same speed up to and including the instant of release. It is not a collision (the hand is not batting the ball, it is throwing it).
So basically you are saying that momentum cannot be conserved in such cases. Just to be sure.. one last example on the same idea.. Having two kids riding the same bike and one of them jumps of landing with zero velocity does not imply that the velocity of the bike will increase. According to you as the boy jumps off he cannot transfer momentum and so the law of conservation of momentum does not apply. Sorry for insisting but these are all examples that we were given and in which the law of conservation was applied.
Momentum is conserved in all cases. Why are you not responding to my posts? I find this very rude.
It is not conserved since there are external forces acting on parts of the system (the horse suddenly stops... what makes it stop?). Any part of the system that is not influenced by those forces will be unaffected and will be effectively their own isolated systems and will retain their own momentum separately.
No! If he jumps off in such a way as to change his own velocity he must do so by imparting a force on the bike and/or other rider. That force interaction is the mechanism for momentum transfer between the elements of the system. In your horse example you did not have the rider jump or push off. You simply had the horse stopped while the rider slid off without friction, i.e., maintained his own momentum independently since there was no force acting between the horse and rider in the direction of motion.
Got it finally. Your help is greatly appreciated!
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 21 ·
