Transformation of acceleration between two reference frames
11 replies · 3K views
Paul Black
hello
i want to derive the Transformation of acceleration between two reference frames
i searched in internet and found a book but i don't understand just one step
i attach a picture so you can see what i found in the internet
my problem is eq. (1.10) \begin{align}du=\frac{dU}{\gamma ^{2}(1-U\frac{v}{c^{2}})^{2}}\end{align}
how did he get this factor
can you please give me a tip
thank you very much
There's a misprint. Calculus rule is d(x/y) = (y dx - x dy)/y2 where x = U - v and y = 1 - Uv/c2, so the first denominator in Eq.(1.10) should be (1 - U v/c2)2. The numerator is dU(1 - v2/c2), which reduces to dU(1/γ2).
thank you for your answer
where is this misprint? is it the first denominator? the square is missing right?
my problem is this gamma in eq 1.10 how did he get it? i don't understand it
also the next step with gamma
can you show me how to get it?
thank you
thank you
There are TWO errors, not one in the book:
[tex]dU=\frac{dU(1-Uv/c^2)-(U-v)(-dUv/c^2)}{(1-Uv/c^2)^2}[/tex]
The final result is correct, the derivation is riddled with errors.
xox thank you for your answer but I am sorry you are wrong
the positive sign is wrong. it must be negative
therefore the only one error is the square in the denominator
but this is not my problem. i just want to know how to get the next step with gamma square.
hope you can help me
There are TWO minus signs, they indeed cancel each other, so I was a little pedantic. [tex]du=\frac{dU(1-Uv/c^2)-(U-v)(-dUv/c^2)}{(1-Uv/c^2)^2}=\frac{dU(1-v^2/c^2)}{(1-Uv/c^2)^2}[/tex]
But [tex]1-v^2/c^2=\frac{1}{\gamma^2}[/tex]
yes you are right
sorryyyy
this gamma confused me xD
Paul Black said:
yes you are right
sorryyyy
You are welcome!
xox
thank you very much. i get it
so now i have to divide both sides by dt to get du/dt=a
but again with this gamma. eq 1.11 i don't understand it
Paul Black said:
xox
OK, let's help u a little more:
We agree that:
[tex]du=\frac{dU}{\gamma^2(1-Uv/c^2)^2}[/tex]
Now,
[tex]dt=\gamma(dT-dXv/c^2)[/tex]
Therefore:
[tex]a=\frac{du}{dt}=\frac{dU}{\gamma^3(1-Uv/c^2)^2(dT-dXv/c^2)}=\frac{dU/dT}{\gamma^3(1-Uv/c^2)^2(1-dX/dTv/c^2)}=\frac{dU/dT}{\gamma^3(1-Uv/c^2)^3}=\frac{A}{\gamma^3(1-Uv/c^2)^3}[/tex]
If [itex]u=V[/itex] then [itex]a=\gamma^3A[/itex]
Paul Black said:
thank you i got it finally
thank you very much
Glad I could help.
