Transformation Of Probability Density Functions
caffeine
Let X and Y be random variables. The pdfs are f_X(x)=2(1-x) and f_Y(y) = 2(1-y). Both distributions are defined on [0,1].
Let Z = X + Y. Find the pdf for Z, f_Z(z).
I'm using ideas, not equations.
I'm dying of curiosity about where I'm going wrong. I'm so sure of each step, but my answer can't be correct because \int_0^2 f_Z(z)\,dz is zero! Here's my logic.
Consider the cdf (cumulative distribution function) for Z:
<br /> F_Z(z) = P(Z\le z) = P(X+Y \le z)<br />
Here, F_Z(z) is the volume above the triangle shown in the image I attached to this message (in case something happens to the attachment, it's the triangle in quadrant 1 bounded by x=0, y=0 and x+y=z.)
The volume above the shaded region represents F_Z(z).
<br /> F_Z(z) = \int_{x=0}^{x=z} 2(1-x)\int_{y=0}^{y=z-x} 2(1-y)\,dy\,dx<br />
Performing the integrals gives F_Z(z) = \frac{1}{6}z^4 - \frac{4}{3}z^3 + 2z^2. Then taking the derivative of the cdf gives the pdf:
<br /> f_Z(z) = \partial_z F_Z(z) = \frac{2}{3}z^3 - 4z^2 +4z<br />
Unfortunately, this can't be right because the integral of this function over [0,2] gives zero.
I also would've expected that the maximum of f_Z(z) would be at z=0 since individually, X and Y are most likely to be zero.
I checked my algebra and calculus with Mathematica; it looked fine. I think there's a conceptual problem. There must be something I don't understand or some point I'm not clear about.
What did I do wrong?
You have to split the problem into different cases.
i) z<0
ii) z<1
iii) 1<z<2
iv) z>2
In each case the area of integration is different. But for each case, your model for the integral is
F_Z(z)=\int\int_{\{(x,y)\in [0,1]\times[0,1]:\ y\leq z-x, \}}f_{XY}(x,y)dxdy
So you're integrating over the area that's the intersection of the square [0,1] x [0,1] with the area under the curve y=z-x.(Btw, you never said that X and Y are independant but I assume they are?)
Ahhh... yes. I *completely* understand.
We're integrating that portion of the unit square (in QI with lower left corner at origin) that lies underneath x+y=1.
So when 0<z<1, there's only one function that represents the "top": the line x+y=z.
And when 1<z<2, there's two functions: y=1 and x+y=z, and therefore we need to break the region of integration into two portions.
Got it. Thanks.
And, yes. :-)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
