Transformations of Double Integrals with Rectangular Domains in the 1st Quadrant
eyesontheball1
Suppose we have the double integral of a function f(x,y) with domain of integration being some rectangular region in the 1st quadrant: 0≤a≤x≤b, 0≤c≤y≤d. Would the following transformation generally be acceptable? (I've quickly tried it out several times with arbitrary integrands and domains, with some instances in which I arrive at the correct answer, and others in which I do not; this leads me to believe that either it is a permissible change of variables but one has to be careful in certain cases, or it's generally not a permissible change of variables, hence the inconsistency in my answers.)
x=rtan(θ), y = rcot(θ), with 0≤[itex]\sqrt{ac}[/itex]≤r≤[itex]\sqrt{bd}[/itex], and 0≤arctan([itex]\sqrt{b/c}[/itex])≤θ≤arctan([itex]\sqrt{a/d}[/itex])≤π/2, s.t. we have dxdy -> |J|drdθ = 2r/cos(θ)sin(θ) drdθ.
I'm unsure of this transformation because although it fails to be one to one on the boundary of the region in the r-theta plane, it's one to one everywhere else, and the determinant only fails to be nonzero at r=0, which lies on the boundary of the said region in the r-theta plane as well.
Thanks in advance!
No, it is not quite valid.
The transformation is fine. The problem is that the rectangle in the xy plane does not transform into a rectangle in your new coordinates.
r and theta usually denote polar coordinates, which these are not, so it is clearer to change the notation a bit.
x = uv, y = u/v
I am setting u=r and v = tan(theta). Now a rectangle in the xy plane has boundaries with either x = const. or y = const.
x = const means uv=const, so you get a hyperbola in the uv plane. Changing v to tan(theta) will give you a different curve, but u and theta will still be dependent on one another.
y=const means u/v=const so you get a straight line through the origin in the u,v plane. Again u depends on v, so changing v=tan(theta) will just mean u depends on theta so you will not get the horizontal or vertical sides of a rectangle.
