Transformer 1:5 ratio with 100A load: source resistance for maximum power transfer
5 replies · 3K views
Kev1n
1. A large power transformer has a turns ratio N1 / N2 of 1:5. When the primary voltage is 400v and it is connected to a resistive load its secondary current is 100A. Calculate the required value of source resistance of the supply to give a maximum power trnasfer
2. Vp = 400v, Ratio 1:5, Is = 100A
3. Vp = 400v, 1:5 Vs = 2000, Is = 100A, 1:5, Ip = 20A
R = Vp/Ip = 4 ohms.
I am a bit lost here, any pointers
R = Vp/Ip = 4 ohms.
So far so good. :cool:
What can you say about "maximum power transfer" of a simple circuit?
The Rp and Rs should be equal?
Is that what you meant
I guess it depends on what you mean by 'Rp' and 'Rs'. But if you define Rp as the resistance in the primary and Rs as the resistance in the secondary, then 'No'. (Transformers not only modify voltage and current, but also impedance.)
Try again by putting things in terms of Rsource and RL, where
Rsource is the source resistance of the supply (which is what you are solving for in this problem), and
RL is the load resistance, as seen by the primary source.
R = Vp/Ip = 4 ohms.
Hello Kev1n,
Forgive me for speaking too soon in my first response. I may have caused some confusion. I seem to have skimmed over your attempted solution, and I missed a mistake.
Your calculation for Ip is incorrect in your original post. And your calculation of R = Vp/Ip = 4 ohms is also incorrect. Forgive me for the confusion of stating "so far so good." :blushing:
But what I said before about transformers changing impedance is true.
