Transforming Y-axis table values into a separate formula?
The discussion centers on calculating time dilation during a 100-second journey with constant acceleration using the formula √(1-v²/c²). The user has generated a velocity vs. time graph with acceleration set at 10^6 km/s² and seeks a method to integrate 100 velocity data points into the time dilation formula efficiently. The conversation highlights the necessity of using relativistic equations instead of Newtonian mechanics to accurately estimate time dilation, particularly as velocities approach the speed of light.
  • Understanding of special relativity and the Lorentz transformation
  • Proficiency in calculus, specifically integration techniques
  • Familiarity with velocity-time graphs and their physical interpretations
  • Basic knowledge of Excel or programming for data manipulation
  • Learn how to implement numerical integration techniques for time dilation calculations
  • Explore Excel functions for handling arrays and applying formulas to multiple data points
  • Study the implications of constant acceleration in relativistic physics
  • Investigate the relationship between kinetic energy and the Lorentz factor (γ)
Physics students, researchers in relativistic mechanics, and anyone interested in applying calculus to real-world physics problems involving time dilation and acceleration.
Sabertooth
Hoping to get some help with the details of Special Relativity in Accelerating frames of reference.
Integrals, Graphing, Velocity. Time dilation factor.
Hey everyone, I have generated a nice little velocity vs time graph that I would love if somebody could help me put to use.
I have marked data points on the x-axis for the Y-value for every second on the function.
Just to be clear: X-axis = time in seconds & Y-axis = velocity in meters/second. We have a constant acceleration.
I have also made an integral of the function, calculating the total area under the curve to be exactly 4.999993*10^9
However, since the 100 data points on the table would be quite tedious to manually apply the time dilation to √1-v^2/c^2 for every seconds at the different velocities. I have wondered whether there is a way to insert the values in my table directly into a calculus such that I retrieve the accumulated amount of time dilation over the 100 second journey depicted on the graph. I think there should be a way integrate these values with the Time dilation factor, even if we have to assume that we travel in constant motion, that increase every second.
Thanks in advance:)
You draw the graph
v=at
where a = 10^6 km/s^2, right?
and you get the value of
x=1/2 \ at^2.
These are Newtonian mechanics.
Then I do not understand your scenario to relate this with \sqrt{1-v^2/c^2} of relativity? What situation you are thinking ?
anuttarasammyak said:
You draw the graph
v=at
x=1/2 \ at^2.
I want to transform every velocity in the table, into the formula: \sqrt{1-v^2/c^2}for 1 second each, then sum them all up to get a good approximation of the total amount of time dilation during this 100 second acceleration. You cannot use Newtonian mechanics, since the Lorentz transformation gets exponentially larger at higher velocities according to special relativity.
There must be somehow, in excel, word or otherwise. To take all these y(velocity) values and plug them all into the formula simultaneously. Or a calculus trick to sum the total amount of time dilation occurring over all these t-intervals.
So for example, at second 1, my velocity is 1 000 000 m/s, at second 2 my velocity is 2 000 000 etc.
For every single time interval I want to plug in my y-values into the formula: \sqrt{1-v^2/c^2} where we insert our 100 different y-values as the v^2 component.
So correspondence
time:speed:time dilation rate is
t : at : ##\sqrt{1-\frac{a^2t^2}{c^2}}##
The y-t graph y= ##\sqrt{1-\frac{a^2t^2}{c^2}}## would be what you want. Area under the graph
\int_0^T \sqrt{1-\frac{a^2t^2}{c^2}} dt < T
is the time reading of the moving clock when time T in the Earth frame of reference.
So correspondence
The graph y= ##\sqrt{1-\frac{a^2t^2}{c^2}}## would be what you want. Area under the graph
The graph shows t in stationary observer time, so that when we plug in the velocities into the formula we should get a lower value t' for the spaceship.
So correspondence
Wow, seems like it worked perfectly. Thanks! I'm getting two different values, depending on whether I square a & x separately. Not sure which one of these is correct and why - however it would be easy to estimate which approach is correct. That's awesome, been spending a bunch of hours on this and you were the saving grace.
Take a look at dimension of the form
\sqrt{1-X^2}
1 is dimensionless. As well X = Z/c should be dimensionless.
\sqrt{1-X^2}
Just found something amazing with this approach, assuming a constant increase in velocity like depicted above, which goes directly to C over 100 seconds. (impossible scenario admittedly) This equation dictates that the minimum t value is equal to exactly t````````'= ((π/4)*100) seconds
\sqrt{1-X^2}
Am I correct in assuming that acceleration and kinetic energy values under the circumstances given in the graph above would transform to the inverse gamma(γ) formula ?
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 20 ·
