Maximize Efficiency with Transmission Line Help - 99.5%, 577.4A, 692.88V
The discussion centers on calculating the efficiency of electricity transmission to a factory using a pair of transmission lines with a total resistance of 1.2 Ω. The factory consumes 400 kW of power, with a power loss of 2 kW in the transmission lines. The efficiency is calculated to be 99.5%, with the current through the lines determined to be 577.4 A and the voltage across the lines calculated as 692.88 V. Participants emphasize the importance of distinguishing between power consumed by the factory and power lost in the transmission lines.
  • Understanding of Ohm's Law (V=IR)
  • Familiarity with power loss calculations (P=I²R)
  • Knowledge of electrical efficiency calculations
  • Basic concepts of electrical units (kW, kV, A)
  • Study electrical efficiency calculations in transmission systems
  • Learn about power loss in electrical circuits and its implications
  • Explore advanced topics in Ohm's Law and its applications
  • Research typical voltage levels in industrial transmission lines
Electrical engineers, power system analysts, and students studying electrical engineering concepts related to transmission efficiency and power loss.
aliserwan
A smaller factory uses 400 kW of power from the electrical grid. The total resistance of the pair of transmission lines carrying electricity to the factory is 1.2 Ω. The heat produced by the pair of transmission lines due to the motion of charges constitutes a loss in the process. The loss is 2 kW.
1-What is the efficiency of electricity transmission?
2- What current is carried by the supplying transmission line?
3- What voltage are the transmission lines connected to?
P=RI^2
V=RI or P/I
a) 99.5%
B) 577.4 A
c) 692.88 V
aliserwan said:
Homework Statement:: A smaller factory uses 400 kW of power from the electrical grid. The total resistance of the pair of transmission lines carrying electricity to the factory is 1.2 Ω. The heat produced by the pair of transmission lines due to the motion of charges constitutes a loss in the process. The loss is 2 kW.
Relevant Equations:: P=RI^2
V=RI or P/I
a) 99.5%
B) 577.4 A
c) 692.88 V
B and C are wrong. Please post your working.
Hint: typical voltage for such would be many kV.
P=R*I^2 so I=(400000/1.2)^0.5=577.4 A
V=R*I so V= 577.4*1.2 =692.88 V
You are confusing the power consumed by the factory with that lost in the wires.
standard unit ? wat/aohm=Amber
v kvolt=kw/amber
if i calculate:
I=(40/1.2)^0.5=18.25
v=I*R=18.25*1.2=21.9
but what about Units ? watt or Kw >> v or kv
efficiency=p-ploss /p =(400-2)/400 = 0.995
Ploss = I^2 * R then I = 40.8 A
P = V * I then V= 9.8 KV
This is a homework thread.
Please read the forum guidelines. We provide hints, point out errors, but do not provide solutions.
aliserwan said:
if i calculate:
You have not understood my post. All you have done there is lose the "k" in kW.
We do not know the resistance of the load in the factory. We know the resistance of the wires, and we know the power lost in the wires, so what is the current through the wires?
Just a note in my capacity as moderator. I just want to reinforce what has been said - hints are provided - not answers. Just as a further hint - we are using KW ie thousands of watts. When calculating remember results will be in thousands as well. Now you know the resistance and power loss hence can calculate the current in thousands of amps. Knowing the resistance and amps, ohms law gives the voltage in thousands of volts across the wires, knowing the current in the device its connected to and power consumed you can calculate the voltage across it. Add them up.
Thanks
Bill
  • · Replies 21 ·
