Transmission line input impedance
The discussion focuses on calculating the input impedance of a 50Ω lossless transmission line of length 0.4λ terminated with a load of (40 + j30)Ω. The phase change, βℓ, is determined to be 2.513 radians. The correct input impedance, after applying the appropriate formula, is calculated as Zin = 25.47 + j5.9Ω. Participants emphasize the importance of using rectangular coordinates for addition and subtraction while converting to polar for multiplication and division.
  • Understanding of transmission line theory
  • Familiarity with complex impedance and phasors
  • Knowledge of the equations for input impedance in transmission lines
  • Proficiency in converting between rectangular and polar forms
  • Study the derivation of the input impedance formula for transmission lines
  • Learn about the effects of load impedance on transmission line performance
  • Explore the significance of reflection coefficients in transmission lines
  • Investigate the use of Smith charts for impedance matching
Electrical engineering students, RF engineers, and professionals working with transmission lines and impedance matching will benefit from this discussion.
acw260
(a) A transmission line has a length, ℓ, of 0.4λ. Determine the phase change, βℓ, that occurs down the line.
(b) A 50Ω lossless transmission line of length 0.4λ is terminated in a load of (40 + j30) Ω. Determine, using the equation given below, the input impedance to the line.
[see attachment for equation]
As above.
(a) β = ω / fλ
∴ βℓ = ω 0.4λ / fλ
= ω 0.4 / f
= 0.4x2π f / f
= 0.8π (=2.513 to 3d.p.)
(b) Zin = 50 x [ (40cos0.8π) / ( 50cos0.8π + 30sin0.8π) ]
= 70.91 ohms
Do these answers look correct? Seems worryingly straightforward.
I think you have to consider the reflection from the mismatched termination.
Ok, I can see that I've manipulated the given formula incorrectly for (b). Second attempt:
Zin = Zo [ ( (ZL COS βℓ) + (jZo SIN βℓ) ) / ( (Zo COS βℓ) + (jZL SIN βℓ) ) ]
= 50 x [ ( (40+j30)COS(0.8π) + (j50)SIN(0.8π) ) / ( 50COS(0.8π) + j(40+j30)SIN(0.8π) ) ]
= 25.47 + j5.9
How does this look?
As above.
(a) β = ω / fλ
∴ βℓ = ω 0.4λ / fλ
= ω 0.4 / f
= 0.4x2π f / f
OK. What was with the ω and f? β = 2π/λ so βl = (2π/λ)(0.4λ) = 2.513 radians.
b) I didn't check your math but the formula you used in your later post looks right.
Hello there, I am struggling with the maths of the equation for b.) Zin = Zo [ ( (ZL COS βℓ) + (jZo SIN βℓ) ) / ( (Zo COS βℓ) + (jZL SIN βℓ) ) ] I have attached my working out and have computed the answer with my calculator in Radians but am not at all confident on the answer I have achieved.
You should have reduced numerator and denominator without changing to polar coordinates:
Z = {(a+jb) + (c+jd)} / {e+jf) + (g+jh)} = {(a+c) + j(b+d)} / {(e+g) + j(f+h)}
THEN changed numerator and denominator to polar.
Rule: for add & subtr, work in rectangular; for mult. & divide, work in polar.
I won't check your math but I suggest you redo using the above stratagem.
hi wanted to put this on as a new post but not sure how so thought it best to place with relevant question
(b) A 50Ω lossless transmission line of length 0.4λ is terminated in a load of (40 + j30)Ω. determine, using the equation given below, the input impedance to the line.
I have calculated Bl which I think is correct and converted the load Zl to polar.
βl + 2π x 0.4 = 0.8π
βl = 2.513 radians = 144°
ZL = 40 + j30Ω
ZL = 50∠36.87°
Am I correct in thinking that the 50Ω of the lossless transmission line is used as the Zo.
once put into the formula the result I get is Zin = 50∠36.87, 40 + j30Ω which is equal to the load which makes me think it is incorrect.
thanks
yes
thanks
i can't check your math but you're on the right track
Thank you rude man for the very fast response, I keep doubting the answers I'm getting and keep trying to find ways to double check my results. I will continue with the assignment and hopefully get it completed soon. cheers
Can I ask how are you getting to this answer mathematically??
There is a point in the equation where j29.5/_36.87 needs to be changed to rectangular form.
This would be J29.5cos(36.87)=j23.6 and J29.5sin(36.87)=JJ17.7
It's at this point JJ17.7 is equal to minus 17.7 and it throws the answer that you are getting out?
If JJ17.7 was equal to +17.7 I get to your answer but j squared x 17.7 is a minus and from there I am not getting to an answer where ZL is equal in Zin.
Am I missing something? :-(
Hi Matt, I only handed the assignment In last Saturday so have just checked if I have yet received any response and I have. it has been highlighted that I have made a sign error and it should have been a minus so you are probably correct. I have just recalculated my equation and the result I now have is 26.143∠13.05, 25.466 + j5.912. is that anything like your answer. cheers
@casper12, instead of "hijacking" a thread that is almost two years old, for future questions, please start a new thread. At the top level of this and other five homework forum sections, there's a button labeled "Post New Thread." Clicking that button presents you with the homework template, which you use to enter the problem statement, relevant formulas, and your work. Do not delete any part of the homework template.
