Transverse Wave on a String: Speed & Acc., Wavelength, Period, Prop. Speed
The discussion focuses on the analysis of a transverse wave on a string represented by the wave function y = (0.120m) sin(π/8 + 4πt). Participants calculated the transverse speed and acceleration at t=0.200s for a point on the string at 1.60m, using the formulas V = -ωA cos(kx - ωt) and A = -ω²A sin(kx - ωt). The wavelength was determined to be 16m, with a period of 0.5s and a propagation speed of 32m/s, confirming the calculations were accurate despite initial confusion regarding the wave function format.
  • Understanding of wave functions and their components
  • Familiarity with angular frequency (ω) and wave number (k)
  • Proficiency in trigonometric calculations in radian mode
  • Knowledge of wave properties such as wavelength, period, and speed
  • Learn about wave function representation in physics
  • Study the relationship between wave speed, frequency, and wavelength
  • Explore the derivation of wave equations for different types of waves
  • Investigate the effects of tension and mass density on wave speed in strings
Students studying physics, particularly those focusing on wave mechanics, as well as educators and tutors looking to clarify concepts related to transverse waves and their properties.
Husker70
A transverse wave on a string is described by the wave function
y = (.120m) sin(pie/8 + 4pie(t))
(a) Determine the transverse speed and acceleration of an element of the
string at t=0.200s for the point on the string located at 1.60m
(b) What are the wavelength, period, and speed of propagation of this wave?
Part (a)
Velocity = -wA cos(kx-wt)
Acceleration = -w^2A sin(kx-wt)
Part B
Wavelength = k = 2pie/lambda
Period = 1/f
Speed = f(lambda)
w = 2pief
f = w/2pie = 2.0 rad/s
Part (a)
V = -(4pie) (.120m)cos(pie/8 + 2.51) I don't know what to do from here
A = -(4pie)^2 (.120m) sin(pie/8 + 2.51) I don't know what to do from here
Part (b)
Wavelength = pie/8 = 2pie/lambda = 16m
Period = 1/2.0 s^-1 = .5s
Speed f(lambda) = (2.0s^-1)(16m) = 32m/s
If anyone can help I would appreciate it.
Thanks,
Kevin
Hi,
Is that supposed to be
(.120m) sin((x)pie/8 + 4pie(t))
(An "x" is needed for this to be a wave.)
Just plug the numbers into your calculator, using radian mode for the sine calculation. And again, please check if it should really be
(x)pie/8
You got the right answer. However, what you wrote here is bad "math grammar". It says (among other things) that
Wavelength = pie/8
which is wrong. pie/8 is actually "k", which as you know is different than wavelength.
A better way to write this out would be something like this:
Wavelength:
k = pi/8 m^-1 = 2pi/lambda
lambda = 2pi / (pi/8 m^-1) = 16 mYour period and speed calculations look correct.
