Triangle Inequality: Prove ||a-b|| for R^n
  • Thread starter Thread starter andrassy
    Calc 3
andrassy
Using the triangle inequality show that for all vectors a, b, c in R^n:
||a-b|| <= ||a - c || + ||c - b ||
(a, b, c are vectors)
The triangle inequality states:
||a+b|| <= ||a|| + ||b||
Im really not sure what to do he made our first problem set due before we finished learning the information. I tried to do something with ||c|| = || sqrt (b^2 - a^c) || (by pythagorean theorem) but i wasn't able to come up with anything. Any guidance in the right direction would be helpful
Also, we are given parametric equations in R^3 and have to determine if the lines are parallel, intersect, or are skew. I can't seeem to find this in the book. Any tips or hints on the general procedure?
Thanks!
Isnt that result just the triangle inequality itself with the 'a' replaced by a-c and the b replaced with the c-b, so that the left hand side ends up being (a-c) + (c-b) = a-b?
Yeah i guess it is but can you do that? How is a = a - c
Oh if you make b = a - c and a = c - b it works and if its a triangle that should be true. THanks!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
