Can You Solve the Triangle Sides Challenge?
  • Context: MHB
  • Thread starter Thread starter anemone
    Challenge Triangle
The discussion centers on proving the equation \((a^2-b^2)(b^2-c^2)(c^2-a^2)=(abc)^2\) for triangle \(ABC\) with angles in the ratio \(1:2:4\). The angles correspond to \(A = 30^\circ\), \(B = 60^\circ\), and \(C = 90^\circ\), indicating that triangle \(ABC\) is a right triangle. Utilizing the sine rule and properties of right triangles, participants confirm the validity of the equation through geometric relationships and algebraic manipulation.
  • Understanding of triangle properties, specifically right triangles.
  • Knowledge of the sine rule and angle ratios in triangles.
  • Familiarity with algebraic manipulation of equations.
  • Basic trigonometric identities and their applications.
  • Study the sine rule and its applications in triangle geometry.
  • Explore properties of right triangles, including the Pythagorean theorem.
  • Investigate angle ratios and their implications in triangle classification.
  • Learn advanced algebraic techniques for manipulating polynomial equations.
Mathematicians, geometry enthusiasts, students studying trigonometry, and educators looking for examples of triangle properties and proofs.
anemone
MHB
POTW Director
It is given that the ratio of angles $A,\,B$ and $C$ is $1:2:4$ in a $\triangle ABC$, prove that $(a^2-b^2)(b^2-c^2)(c^2-a^2)=(abc)^2$.
Mathematics news on Phys.org
We see that angles $A,\,B$ and $C$ are $\frac{\pi}{7}$, $\frac{2\pi}{7}$ and $\frac{4\pi}{7}$
and using laws of sines we need to prove
$(\sin ^2 A -\sin ^2 B)(\sin ^2 B - \sin ^2 C)(\sin ^2 C - \sin ^2 A)= (\sin\,A \sin\,B \sin\, C)^2$.
where $A= \frac{\pi}{7}$ $B= \frac{2\pi}{7}$ and $C= \frac{4\pi}{7}$
to avoid fraction let $x =\frac{\pi}{7}$ so $A= x$ $B= 2x$ and $C= 4x$
so $\sin\,x = \sin 6x$ and $\sin 3x = \sin 4x$
we shall be using the following
$\sin\, X + \sin \,Y = 2 \sin \frac{X+Y}{2} \cos \frac{X-Y}{2}\cdots(1)$
$\sin\, X - \sin \,Y = 2 \sin \frac{X-Y}{2} \cos \frac{X+Y}{2}\cdots(2)$
So
$\sin ^2 X - \sin ^2 Y$
= $(\sin\, X + \sin \,Y)(\sin\, X - \sin \,Y)$
= $ (2 \sin \frac{X+Y}{2} \cos \frac{X-Y}{2})(2 \sin \frac{X-Y}{2} \cos \frac{X+Y}{2})$
= $ (2 \sin \frac{X+Y}{2} \cos \frac{X+Y}{2})(2 \sin \frac{X-Y}{2} \cos \frac{X-Y}{2})$
= $ \sin (X+Y)\sin(X-Y)$
Now
LHS
= $(\sin ^2 A -\sin ^2 B)(\sin ^2 B - \sin ^2 C)(\sin ^2 C - \sin ^2 A)$
= $(\sin ^2 x -\sin ^2 2x)(\sin ^2 2x - \sin ^2 4x)(\sin ^2 4x - \sin ^2 x)$
= $(\sin ^2 2x -\sin ^2 x)(\sin ^2 4x - \sin ^2 2x)(\sin ^2 4x - \sin ^2 x)$ multiplying 1st and 2nd terms by -1
= $\sin 3x \sin \,x \sin 6x \sin 2x \sin 3x \sin \,x $
= $\sin 4x \sin \,x \sin x \sin 2x \sin 3x \sin \,x $ as $\sin 3x = \sin 4x$ and $\sin 6x =\sin \,x $
= $(\sin\,x \sin 2x \sin 4x)^2$
= $ (\sin\,A \sin\,B \sin\, C)^2$
= RHS
Proved
[TIKZ]\draw circle (4cm) ;
\coordinate [label=right:{$1=\omega^7$}] (A) at (4,0) ;
\coordinate [label=above right:$\omega$] (B) at(51.4:4cm) ;
\coordinate [label=above:$\omega^2$] (C) at(102.8:4cm) ;
\coordinate [label=left:$\omega^3$] (D) at(154.3:4cm) ;
\coordinate [label=left:$\omega^4$] (E) at(205.7:4cm) ;
\coordinate [label=below:$\omega^5$] (F) at(257.1:4cm) ;
\coordinate [label=below right:$\omega^6$] (G) at(308.5:4cm) ;
\draw (A) -- node [above right]{$a$} (B) -- node[above]{$b$} (D) -- node[below]{$c$} (A) ;
\foreach \point in {A,B,C,D,E,F,G} \fill (\point) circle (2pt) ;[/TIKZ]
Let $\omega = e^{2\pi i/7}$. The triangle with vertices at $1$, $\omega$ and $\omega^3$ has the correct angles. Its sides have lengths $a = |\omega-1|$, $b = |\omega^3 - \omega|$, $c = |\omega^3-1|$. Then (using the fact that $|z|^2 = z\overline{z}$) $$ a^2 = (\omega-1)(\omega^6-1) = 2 - \omega - \omega^6, \\b^2 = (\omega^3-\omega)(\omega^4-\omega^6) = 2 - \omega^2 - \omega^5, \\c^2 = (\omega^3-1)(\omega^4-1) = 2 - \omega^3 - \omega^4,$$ $$ a^2-b^2 = \omega^2 + \omega^5 - \omega - \omega^6 = -\omega(\omega-1)(\omega^4-1), \\b^2-c^2 = \omega^3 + \omega^4 - \omega^2 - \omega^5 = -\omega^2(\omega-1)(\omega^2-1), \\c^2-a^2 = \omega + \omega^6 - \omega^3 - \omega^4 = \omega^8 + \omega^6 - \omega^{10} - \omega^4= -\omega^4(\omega^2-1)(\omega^4-1).$$ Therefore $(a^2-b^2)(b^2-c^2)(c^2-a^2) = - (\omega-1)^2(\omega^2-1)^2(\omega^4-1)^2.$
Also, $$ a^2 = (\omega-1)(\omega^6-1) = (\omega-1)(\omega^6-\omega^7) = -\omega^6(\omega-1)^2, \\b^2 = (\omega^3-\omega)(\omega^4-\omega^6) = -\omega^5(\omega^2-1)^2, \\c^2 = (\omega^3-1)(\omega^4-1) = (\omega^3-\omega^7)(\omega^4-1) = -\omega^3(\omega^4-1)^2,$$ from which $(abc)^2 = - (\omega-1)^2(\omega^2-1)^2(\omega^4-1)^2.$
Comparing those two outcomes, $(a^2-b^2)(b^2-c^2)(c^2-a^2) = (abc)^2.$
