Trig Function Help: Get Answers Now
  • Thread starter Thread starter Eric Manuel
    Function Trig
The discussion revolves around a trigonometric problem involving the double angle formula for cosine, specifically cos(2t). Participants are attempting to clarify the problem's requirements and the values needed for calculations.
  • Participants inquire about the specifics of the problem, including the variable involved and the need for using the double angle formula. There are discussions about finding values for sine and cosine using a reference triangle and the relationships between cotangent and tangent.
Several participants are actively engaging with the problem, sharing their interpretations and calculations. Some guidance has been offered regarding the use of trigonometric identities and the reference triangle method, though no consensus has been reached on the final answer.
There is mention of a teacher's requirement to understand the concepts without a calculator for a test, which adds a layer of complexity to the discussion. Participants are also exploring the implications of the given cotangent value.
Eric Manuel
thanks
Can you give the entire problem?
all that's given is that
What is the question? What are you asked to find?
what is =cos2x
What is x supposed to be? Is the given problem in terms of t? Are you trying to solve for t and then plug that value in for x?
oh my bad its cos2t
its basically asking you to use the double angle formula
but I am not sure how to find those values
If you're simply trying to find t, then use cot = 1/tan... If you have a value for t why do you need to use the double angle identities?
to find what cos2t is ...
you can find what tan is from cot
then i drew a triangle and got the hypot to be sqrt(41)
but how do i do that math
formula for cos2t = cos^2(t) - sin^2(t)
Are you forbidden from using a calculator?
teacher said u can use it
but need to know how to do it without one for test
Well that may have been useful information at the start...
you have cot = -5/4, find what tan is then recall tan = sin/cos ... or recall cot = cos/sin...
well i worked it out and i believe i got the answer to be 9/41
That's what I'm getting
