jog511
- 23
- 0
lim x->0 sin4x/2x
lim x->0 sinx/x =1
can I write lim x->0 sin4x/2x as sinx/x * 4/2 = 1*2 or am I missing a step ?
The discussion revolves around evaluating the limit of the function lim x->0 sin(4x)/2x, which involves understanding the behavior of trigonometric functions as they approach zero.
Participants have engaged in a back-and-forth regarding the correct form of the limit and the constants involved. Some have suggested using L'Hôpital's rule as an alternative method, while others are focused on rewriting the expression to match a standard limit form.
There is mention of the "indeterminate form" 0/0 when evaluating the limit directly, which leads to discussions about applying L'Hôpital's rule. Participants also express confusion about the concepts involved, indicating that the material may not be clearly explained in their resources.
]No, one cannot do that. There is no rule that says one can pull out a factor from a trig function like this. You have to rewrite you expression in the formjog511 said:Homework Statement
lim x->0 sin4x/2x
lim x->0 sinx/x =1
I have no idea what you mean by that. But surely you know that sin(2x) is NOT equal to 2sin(x)?jog511 said:like 4/4
nrqed said:Set aside the limit for now. Try writing the expression in the form C \, \sin(y)/y. What is y(x)? What is C?
jog511 said:sin4x/2x * 4/4 = 4*sin4x/4*2x
jog511 said:C = 4,
y(x) = 4x
jog511 said:I believe I get sin4x/4x
nrqed said:Hold on. If y =4x and C = 4 then
C \sin(y)/y = 4 \frac{ \sin(4x) }{4x}
right? This is not the initial expression.
jog511 said:I don't understand this concept. Even Calculus by Larson does not explain it well.
jog511 said:c in the original equation was 1
Correct.jog511 said:It has to be 2
jog511 said:thanks for your patience
