Trig integration complex analysis
4 replies · 4K views · last reply
Dustinsfl
\int_0^{\pi}\frac{ad\theta}{a^2 + \sin^2\theta} = \int_0^{2\pi}\frac{ad\theta}{1 + 2a^2 - \cos\theta} = \frac{\pi}{\sqrt{1 + a^2}}
Consider $a > 0$ and $a < 0$
First I don't think the second part is correct. Shouldn't it be $1 + 2a^2 - \cos 2\theta$?
Hi dwsmith,
Using the double angle formula, $\cos 2\theta = 1-2\sin^{2}\theta\Rightarrow \sin^{2}\theta = \dfrac{1-\cos 2\theta}{2}$
\[\therefore\int_0^{\pi}\frac{ad\theta}{a^2 + \sin^2\theta} = \int_0^{\pi}\frac{2ad\theta}{1 + 2a^2 - \cos 2\theta}\]
Now use the substitution, $u=2\theta$. Then,
\[\int_0^{\pi}\frac{ad\theta}{a^2 + \sin^2\theta} = \int_0^{\pi}\frac{2ad\theta}{1 + 2a^2 - \cos 2\theta}=\int_0^{2\pi}\frac{adu}{1 + 2a^2 - \cos u}\]
Since the variable in a definite integral doesn't have any significance you can replace $u$ by $\theta$. So the second part is correct. It involves two substitutions to get there. I think this clarifies your doubt. :)
So by a Theorem from Complex Analysis by Lang (dont have book with me so I can't quote it), I can write $\frac{a}{1 + 2a^2 - \cos\theta}$ as
\frac{2a}{-z^2 + (4a^2 + 2)z -1}
Then
z= 2a^2+1\mp 2a\sqrt{a^2+1}
So
\frac{2a}{(z-2a^2-1+ 2a\sqrt{a^2+1})(z-2a^2-1- 2a\sqrt{a^2+1})}
So now I need to determine which poles are in the unit circle so I can apply the theorem that integral is the 2\pi times the sum of residues in the unit circle.
I am not sure how I can determine which pole(s) would be in the unit circle.
chisigma said:
If the poles are...
$\displaystyle z= 2\ a^{2}+1 \pm\ 2\ a\ \sqrt{a^{2}+1}$ (1)
... then is...
$\displaystyle |z|^{2}= (1+2\ a^{2})^{2} + 4\ a^{2}\ (1+a^{2})$ (2)
... so that You have to find the values of a for which is $\displaystyle |z|^{2}<1$...
Kind regards
$\chi$ $\sigma$
After simplifying, we obtain
8a^2(a^2+1)<0
which is never true for any real a.
---------- Post added at 14:55 ---------- Previous post was at 14:40 ----------
8a^2(a^2+1)<0
I think I figure it out the it has to be $z= 2a^2+1-2a\sqrt{a^2+1}$.
There has been a trivial error from me reading Your message... I'm very sorry!(Headbang)...
If the definite trigonometric integral is...
$\displaystyle \int_{0}^{2 \pi} \frac{a}{1+2\ a^{2} - \cos \theta}\ d \theta$ (1)
... then the integral in the complex plane becomes...
$\displaystyle \int_{C} \frac{2\ i\ a}{z^{2}-2\ (1+2\ a^{2})\ z +1}\ dz$ (2)
... and the pole of the function are...
$\displaystyle z= 1 + 2\ a^{2} \pm a\ \sqrt{1+a^{2}}$ (3)
The remaining is left to You...
Kind regards
$\chi$ $\sigma$
