Trig Question: Exact value of
  • Thread starter Thread starter nukeman
    Trig Value
To find the exact value of sin(11π/2), it's essential to determine the coterminal angle within the range of [0, 2π). By subtracting multiples of 2π, it can be simplified to 3π/2. The sine of 3π/2 corresponds to the point (0, -1) on the unit circle, leading to the conclusion that sin(11π/2) equals -1. Understanding coterminal angles and the unit circle is crucial for solving such trigonometric problems. This method provides a clear path to the solution without needing a calculator.
nukeman
Trig Question: Exact value of ...
Find the exact value of:
sin(11"pi" / 2)
without a calculator...
I don't understand how to solve this with the unit circle. What is my first step here?? My textbook just gives the answer, and not how to solve it.
THanks for any help!
try converting 11pi/2 into degrees then looking at the unit circle
Find the angle in [0, 2π) that is coterminal to 11π/2.
As an example, if I wanted to find cos(15π/4), I note that
cos(15π/4) = cos(7π/4)
and this angle is in [0, 2π), so it's straight forward to evaluate it.
cos(7π/4) = √2/2
You'll have to do something similar in your problem.
sin(11"pi" / 2)
If you start at zero and rotate the radius through that angle, where does it end up? (The "exact value without a calculator" is a hint that it will be equal to one of the common angles.)
Here is what I came up with...Im sure there is a better way of solving this!
TO convert into degrees, I get 990. So, that's 360 + 360 + 270, which according to the unit circle is (0,-1), so since its sin, the answer will be -1
That seems like the wrong way of firguring this out...
But how does 11pi/2 equate to 3pi/2
Read up on coterminal angles in your textbook (assuming you have one).
11*pi/2
A quarter revolution in radians of the unit circle is half a pi (since four quarters aka a complete revolution is 2pi)
Now just start counting :)
"But how does 11pi/2 equate to 3pi/2"
One revolution of the unit circle is 2 pi, therefore wherever you are, you can go 2pi around, you end up in the exact same spot. Any n*pi/2 -/+ 2pi = n*pi/2 is exactly the same if used in a trigonometric function
You can do the same thing without bothering to convert to degrees first. Every time you go around the circle corresponds to 2\pi, so subtract off multiples of 2\pi. What does that leave you?
Or it could refer to sum, difference, half or double angle identities.:rolleyes:
Personally, I find the unit circle very helpful, but you could graph the function in an x-y plot (I'm presuming you understand the period of the sin function at least visually).
  • · Replies 33 ·
