Trig Solve for Solution Within Interval
  • Thread starter Thread starter catenn
    Interval Trig
The discussion centers on solving the equation (√2)(cos 2θ) = 1 within the interval 0 < θ < 2π. The correct solution for θ is identified as θ = π/8, with additional solutions including θ = 15π/8. The participants emphasize the importance of correctly applying the double angle formula for cosine and the need to consider the unit circle for accurate angle determination.
  • Understanding of trigonometric identities, specifically the double angle formula for cosine.
  • Familiarity with the unit circle and its properties.
  • Basic algebraic manipulation skills, including solving equations involving trigonometric functions.
  • Knowledge of radians and how to convert between degrees and radians.
  • Study the double angle formulas in trigonometry, focusing on cos(2θ).
  • Practice solving trigonometric equations within specified intervals.
  • Explore the unit circle and its application in solving trigonometric problems.
  • Learn about periodicity in trigonometric functions and how to find general solutions.
Students and educators in mathematics, particularly those focusing on trigonometry, as well as anyone needing to solve trigonometric equations within specific intervals.
catenn
Hi, I have a problem that says to solve this equation for the interval 0<theta<2 pie which is one revolution of the unit circle. The equation is:
(square root of 2)(cos 2theta) = 1
The cos2theta is a double angle, but I couldn't find any solutions for theta that would = 1 at the end. The answer has to fit in for the theta angle. Is this possibly no solution? I had originally put pie/4 as an answer but realized I forgot the parenthesis in the calculator and now I need to redo the problem. Thanks!
Draw the unit circle in the x-y cartesian plane. If you rotate around the circle by an angle \theta counterclockwise wrt the positive x-axis, then \cos{\theta} is the x-coordinate of the resulting point. So what \theta will make \cos{\theta} = \frac{1}{\sqrt{2}} (HINT: What's 2(1/\sqrt{2})^2?)?
Edit: courtrigrad I suggest plugging \pi / 2 into \sqrt{2}\cos{2\theta} and seeing what you get :-p
my fault it should have been \theta = \frac{\pi}{8}. I multiplied instead of divided.
You can give a closed form for \theta.
Edit: :smile:
\theta = \frac{\pi}{8} + 2n\pi
he said 0 &lt; \theta &lt; 2\pi though (of course, there's still \theta = \frac{15}{8} \pi!) :-p
Thank you both so much for the help! I really appreciate it and understand now.
  • · Replies 30 ·
