Triginometry: Half Angle Identities
  • Thread starter Thread starter StephenAA
    Angle identities
The forum discussion focuses on solving the trigonometric problem of finding sin(75°) using half-angle identities. The correct answer is established as sin(75°) = (√6 + √2)/4. The discussion emphasizes the use of the half-angle identity sin(α/2) = ±√((1 - cos(α))/2) and the importance of simplification steps, including recognizing algebraic patterns. Additionally, it clarifies that the positive value should be retained due to the quadrant in which 75° lies.
  • Understanding of trigonometric identities, specifically half-angle identities
  • Familiarity with the unit circle and quadrant analysis
  • Basic algebraic manipulation skills
  • Knowledge of the sine and cosine functions and their properties
  • Study the derivation and applications of half-angle identities in trigonometry
  • Learn about the sum and difference formulas for sine and cosine functions
  • Practice simplifying trigonometric expressions using algebraic techniques
  • Explore the unit circle to understand the signs of trigonometric functions in different quadrants
Students studying trigonometry, educators teaching trigonometric identities, and anyone seeking to enhance their problem-solving skills in trigonometric equations.
StephenAA
sin(75^\circ)
sin(\frac{\alpha}{2}) = \pm \sqrt{\frac{1-cos(\alpha)}{2}}
The answer is known to be:
\frac{\sqrt{6} + \sqrt{2}}{4}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{1-cos(150^\circ)}{2}}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{1+\frac{\sqrt{3}}{2}}{2}}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2+\sqrt{3}}{4}}
sin(\frac{150^\circ}{2}) = \pm \frac{\sqrt{2+\sqrt{3}}}{2}
This is a correct answer, but clearly it is not simplified completely. Any help would be appreciated.
Are you supposed to use the half-angle identity? Think of another way to figure it out.
Hint: Sum Formula for sin function.
Yes. As you stated, this problem can be solved easily with the sum formula for sin, but the directions ask us specifically to solve it using half angle identities. My problem is that I get stuck at that last step, as I'm not quite sure how to simplify it further.
First off, do we NEED the plus-minus sign? (If not, can you explain why not?)
The 2nd to last line you have this:
Inside the square root, multiply top and bottom by 4. Factor out a 2 in the numerator (not 4!). You should have
\sin \left(\frac{150^\circ}{2}\right) = \sqrt{\frac{2(4 + 2\sqrt{3})}{16}}
Split the 4 into 1 + 3:
\sin \left(\frac{150^\circ}{2}\right) = \sqrt{\frac{2(1 + 2\sqrt{3} + 3)}{16}}
This expression:
1 + 2\sqrt{3} + 3
is an algebraic pattern that's somewhat disguised. See if you can figure out the rest.
I'm not entirely sure how to determine whether the answer should be positive or negative (the quadrant, perhaps?), so I just left it there.
Anyways, thanks for your help. It's much more clear now.
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{8+4\sqrt{3}}{16}}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(4+2\sqrt{3})}{16}}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(1+2\sqrt{3}+3)}{16}}
sin(\frac{150^\circ}{2}) = \pm \sqrt{\frac{2(1+\sqrt{3})^2}{16}}
sin(\frac{150^\circ}{2}) = \pm \frac{(\sqrt{2})(1+\sqrt{3})}{4}
For the final answer:
sin(75^\circ) = \pm \frac{\sqrt{2}+\sqrt{6}}{4}
Or, as the answer key lists it:
sin(75^\circ) = \pm \frac{\sqrt{6}+\sqrt{2}}{4}
Thank you for your help.
Yes, but not quite. sin(75o) is a positive value, so you need to discard the negative value.
