MHB How Can I Evaluate Trig Functions Without a Calculator?
This discussion centers on evaluating trigonometric functions, specifically cos(3), without a calculator, as outlined in Section 6.2 of David Cohen's precalculus textbook. Participants confirm that cos(3) is negative since 3 radians lies in the second quadrant of the unit circle. Additionally, a method using the Maclaurin series is proposed for approximating cos(3) to a desired accuracy, yielding an approximation of -0.9748. The conversation emphasizes the importance of understanding the unit circle and series expansions in trigonometry.
  • Understanding of the unit circle and its quadrants
  • Familiarity with radians and their relation to angles
  • Basic knowledge of Maclaurin series for function approximation
  • Ability to perform series summation and approximation techniques
  • Study the unit circle and its quadrants in detail
  • Learn about radians and their conversions to degrees
  • Explore the Maclaurin series and its applications in trigonometry
  • Practice evaluating trigonometric functions using series expansions
Students studying precalculus, mathematics enthusiasts, and anyone looking to deepen their understanding of trigonometric function evaluation without calculators.
mathdad
I am in the trigonometry section of my precalculus textbook by David Cohen. In Section 6.2, David explains how to evaluate trig functions without using a calculator but it is not clear to me.
Sample:
Is cos 3 positive or negative?
How do I determine if cos 3 is positive or negative without using a calculator?
Is the unit circle needed in this case?
Mathematics news on Phys.org
Sample:
I don't see any "evaluate" in your examples. All I see is a suggestion that we can gain SOMETHING rather easily.
3 is pretty close to $pi$. It's a little less. Is cosine positive or negative over on the $pi$ side of the Unit Circle?
Cosine is negative in quadrant 2.
So, cos 3 is negative.
- - - Updated - - -
What if the question is EVALUATE cos 3 without using a calculator? Do we need the unit circle?
RTCNTC said:
...What if the question is EVALUATE cos 3 without using a calculator? Do we need the unit circle?
I would likely use a Maclaurin series to approximate $\cos(3)$ to the desired accuracy, if asked to do so by hand.
$$\cos(x)=\sum_{k=0}^{\infty}\left(\frac{(-1)^k}{(2k)!}x^{2k}\right)$$
Thus:
$$\cos(3)=\sum_{k=0}^{\infty}\left(\frac{(-1)^k}{(2k)!}9^{k}\right)$$
If we use the first 5 terms, we obtain:
$$\cos(3)\approx1-\frac{9}{2}+\frac{81}{24}-\frac{729}{720}+\frac{6561}{40320}=-\frac{4367}{4480}\approx-0.9748$$
According to W|A, we have:
$$\cos(3)\approx-0.9899924966004454$$
Thus:
MarkFL,
You are a true mathematician. I am far from your level of understanding mathematics. I am not familiar with the Maclaurin series. It looks very interesting but I am not there yet. Is my reply concerning cos 3 being negative correct, good or bad?
RTCNTC said:
MarkFL,
Yes, 3 radians is in quadrant II, and so the cosine of that angle is negative. As stated 3, is close to $\pi$, and so we should expect $\cos(3)$ to be close to -1. :)
When I get home tonight, I will work on selected questions from Section 6.2. If I get stuck, like always, I will come back here with my questions, and my math work seeking help. Thank you so much for your help, and your patience as I travel through the wonderful David Cohen textbook.
  • · Replies 27 ·
