Trigonometric Identity: Double Angle.
6 replies · 3K views
Jessbek
Here is the question given:
A blade for a lawnmower consists of two parts made of the same material and joined together as shown:
The length OP is one unit in length and MPQN is square in shape.
Develop an equation for the cross-sectional area of the blade and find the magnitude of angle ∅ to give the area of the blade.
sin 2 ∅ = 2 ((sin ∅) (cos ∅)
Attempt? I've tried deriving the double angle equation but can't get anywhere... :( basically there is only one known piece of info (in the hypotenuse being one unit in length)...
I guess you mean express the area of the blade in terms of ##\phi##. Use trig to express PM and OM in terms of ##\phi##, then use that to calculate the two areas.
I know what you mean and thank you.
But what I don't know is what to do from there to get some physical/actual answer...
Well, I don't know what else to do either because the statement "find the magnitude of angle ∅ to give the area of the blade" doesn't mean anything to me.
I think it simply means find the value of theta, and in turn, use that value to find the surface area of the blade.
But there isn't "a value of ##\phi##". As ##\phi## varies so does the area. You can express the area in terms of ##\phi##. I think the rest of the problem isn't properly stated.
I know and this is what confuses me. You can express the area in terms of ##\phi## yes, but this won't get me anywhere. I have written the question essentially the same, so maybe there is an error with the question.
