Trigonometric Inverse Substitution: How do we know which substitutions to use?
The discussion revolves around the use of trigonometric substitutions in integration, specifically focusing on the substitution \( x = a \sin \theta \) for integrals involving the form \( \sqrt{a^2 - x^2} \). Participants explore how one can determine the appropriateness of such substitutions in advance, questioning whether it is based on intuition, trial and error, or established reasoning.
  • Some participants suggest that the substitution \( x = a \sin \theta \) is intuitive due to its geometric interpretation related to the unit circle and right triangles.
  • Others argue that the effectiveness of the substitution may not be known in advance and could rely on trial and error.
  • A participant mentions that using trigonometric identities can simplify the integration process when employing such substitutions.
  • Another participant proposes an alternative substitution, \( x = a \tanh t \), indicating that different substitutions may also be valid.
  • Several participants reiterate the connection between the substitution and the identity \( \sin^2(t) + \cos^2(t) = 1 \), suggesting that this identity underpins the reasoning for the substitution.
Participants express differing views on whether the appropriateness of trigonometric substitutions can be determined in advance. While some find it intuitive, others maintain that it often comes down to trial and error. No consensus is reached on a definitive method for selecting substitutions.
The discussion highlights the reliance on geometric interpretations and trigonometric identities, but it does not resolve the underlying assumptions about the effectiveness of various substitutions or the completeness of the reasoning provided.
tahayassen
If we see the form [itex]\sqrt { { a }^{ 2 }-{ x }^{ 2 } }[/itex], we always set [itex]x=asinθ[/itex]
How do we know that it will work in advance? Just trial & error?
Work in advance to do what exactly? If you had to integrate that radical, then we would just try a substitution to eliminate the radical.
Putting x=asint or x=acost will both capitalize on the fact that sin2t+cos2t=1
hi tahayassen! :smile:
we don't know, but if a substitution will work, it'll be that one :wink:
The context here is integration using trig substitution. It's similar to ordinary substitution except that you are using a trig function.
Trig substitutions are used most often for the square roots of a sum of squares or a difference of squares. For ##\sqrt { a^2 - x^2 } ##, the idea is that you are using a right triangle with an acute angle θ. The hypotenuse is of length a, and the side opposite the acute angle is of length x. From these relationships, we get
sin θ = x/a, or x = a sin θ.
Taking differentials, we get dx = a cos θ dθ.
If the quantity under the radical is x2 - a2, label the hypotenuse as x and one of the other sides as a.
If the quantity under the radical is a2 + x2, label the legs of the triangle as a and x, and the hypotenuse as ##\sqrt{a^2 + x^2}##. With this arrangement, tan θ = x/a (assuming the side across from the angle is labelled x).
Its very intuitive actualy. The equation of a circle with radius r centered in the coordinate system is [itex]y^2+x^2=r^2[/itex]. Your expression [itex]\sqrt { { a }^{ 2 }-{ x }^{ 2 } }[/itex] is just a semi circle with radius a. In trigonometry circle with radius one is used to represent trigonometric functions using the coordinates. Since the radius is a and your coordinates are forming a right triangle with hypotenuse a you can use trig identities and substitute with sine of an angle multiplied by the radius of the circle.
The point in this is when you factor out a that 1-sin^2(z)=cos^2(z) .You will be left with a square of a single function in the square root. By using trigonometric identities for square of trig functions you can actualy simplify by finding the integral of trig function of the double angle.
[itex]x=asinz; dx=acoszdz[/itex]
[itex]\int \sqrt{a^2-a^2sin^2z}acoszdz=[/itex][itex]a\int \sqrt{1-sin^2z}acoszdz[/itex][itex]= a^2\int \sqrt{cos^2z}coszdz =[/itex][itex]a^2\int cos^z dz[/itex]
[itex]cos^2z=\frac{cos2z+1}{2}[/itex][itex]\frac{a^2}{2}\int cos2zdz+\frac{a^2}{2}\int dz[/itex][itex]= \frac{a^2sin2z}{4} + \frac{a^2z}{2} + C[/itex]
This contains most methods involving trigonometric substitution, and probably is the most usefull calculus reference sheet I have ever found. Link.
We get this one from the identity [itex]sin^2(t)+ cos^2(t)= 1[/itex] so that [itex]cos^2(t)= 1- sin^2(t)[/itex], [itex]cos(t)= \sqrt{1- sin^2(t)}[/itex] so that the square root on the right does not occur on the left.
I'd try [itex]x = a\tanh t[/itex]
