Trigonometry Arc Length Problem
6 replies · 2K views
Euler2718
First I'd just like to point out that I'm taking calculus and advance pre-calculus simultaneously (kind of a stupid system) and this is a problem in the pre-calc.
1. Homework Statement
2. Homework Equations
Let 'a' be arc length.
[tex]a=\theta r[/tex]
[tex]a = \int_{a}^{b} \sqrt{1+[f'(x)]^{2}} dx[/tex]
3. The Attempt at a Solution
The lecture on arc length wasn't even a lecture. Merely a hand out of the chapter summery, not to be touched again. I saw no central angle so [tex]a=\theta r[/tex] seems to be out of the question. This seemed to be an unusual problem, so I used Pythagoras after a while. I went
[tex]( \Delta x )^{2} + (\Delta y)^{2} = a^{2}[/tex]
This yields the arc length to [tex]\sqrt{8}[/tex] units.
I confirmed this with the integration for arc length. But I'm really not at the level of arc length integration yet. I can do basic integration only (I skipped ahead in the course a bit). Via wolfram alpha:
[tex]\int_{-8}^{-6} 10\sqrt{\frac{1}{100-x^{2}}} dx = 10\sin ^{-1}\left(\frac{7}{25}\right) \approx 2.83794[/tex]
Which is pretty much [tex]\sqrt{8}[/tex] So really, my question is if there is another more formal way to approach this problem using trigonometric concepts to arrive at an answer.
Thank you in advance.
phinds said:
Can you figure out the angle AQB?
Ahhh. Using the right triangles no doubt. I'll give it a go. Thanks.
Problems involving derivatives or integrals should be posted in the calculus section, not in the precalculus section. I have moved this thread.
Sorry. I merely included the calculus to show what I used to compute the answer, as it was technically part of my attempt.
Pretty sure I got it now! Thank you phinds for the tip. I calculated the central angle to be 16.3°, and used the arc length equation from there. It comes out to 2.8 units, which is what the Pythagorean approximation and the integration came to.
