Why Might High Speed Trip Relays Malfunction in Bus Bar Protection Schemes?
  • Thread starter Thread starter m.s.j
    Relay
The discussion centers on the malfunction of high-speed trip relays in bus bar protection schemes for double bus high voltage substations. The protection systems design group selected a relay with a 4 ms operation time and a 2.5W DC bobbin to minimize thermal stress on output contacts. However, during pre-commissioning, mal-operation was reported alongside a DC battery system alarm for Earth leakage. The exact cause of the malfunction remains unclear, with suggestions including potential insulation damage in the wiring.
  • Understanding of high voltage substation design principles
  • Knowledge of high-speed trip relay specifications and operation
  • Familiarity with DC battery systems and their alarms
  • Basic concepts of electrical insulation and fault conditions
  • Investigate the impact of insulation integrity on relay performance
  • Research best practices for designing bus bar protection schemes
  • Learn about troubleshooting DC battery systems in high voltage applications
  • Explore the specifications and operational limits of high-speed trip relays
Electrical engineers, protection system designers, and technicians involved in high voltage substation operations and maintenance will benefit from this discussion.
m.s.j
In a bus bar protection scheme applied for a double bus high voltage substation, protection systems design group have chosen high speed trip relay with operation time equal to 4 ms and a 2.5W DC bobbin; because they want to decrease the thermal stresses on output contacts of protection relays. As you know in high impedance bus bar protection scheme they must start several trip relays in bus bar faulty conditions simultantinusly.Therfore, dc circuit currents specially the circuits that involve to protective relays, must be considered carefully in detail design step.
But in practice they met some mal-operation of trip relay in pre-commissioning stage. According to pre-commissioning reports,
mal-operation had been accompanied with a DC battery system alarm for Earth leakage.
Can you explain the reason of that mal-operation?
BEST REGARDS
MSJ
Creative thinking is enjoyable,Then think about your surrounding things and other thought products. http://electrical-riddles.com
There is not enough information provided to explain that malfunction. There could be damaged insulation in the wires. We just can't tell.
The malfunction is not necessarily related to the double bus high voltage substation protection application.
